Control arm recommendation - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Roush Mustang
Old 04-17-2015, 02:04 AM   #1
Anyone have any experience on Controls arms on supercharged mustangs? I have a 2013 Mustang with the 627 hp whipple supercharger kit and a few other small mods on the Ford racing Cal 2 safe tune and of coarse I have some wheel hop! Lol I have elbach lowering sport Springs and adjustable elbach penard bar as well, what controls arms do you guys think I should purchase and should I get the upper and lower control arms?
mosh350 is offline   Reply With Quote
Old 05-12-2015, 07:10 PM   #2
Yes you will need upper and lower control arms, personally I think BMR makes GREAT parts!! Wheel hop is pretty hard on your car, you need to eliminate that asap
Phase 3 upgrade including CAI, Fuel pump voltage regulator, (648rwhp), 582 torque, Kooks LT headers with off road H pipe, Vossen CV3's, ID1000's, Steeda Heat Exchanger, BMR LCA's,relocation brackets, adjustable Panhard bar, Rear sway bar, Steeda Aluminum driveshaft, X-brace, Differential cover, torque box brace/frame rails, Shelby trans cooler, Mcleod RST clutch/lightweight steel flywheel w/SS clutch line, RP fluids, whiteline transmission bushing,MGW race spec short shifter,Ford racing twin 65mm throttle body, Pro Dyno tuned
jamyzd30 is offline   Reply With Quote
Old 05-12-2015, 09:11 PM   #3
EXCATLY! And thanks for the reply! Yea I was actually looking at bmr or elbach since I have the elbach lowering Springs and adjustable penard bar
Old 05-12-2015, 09:47 PM   #4
No problem man. You spend enough money on your mods so far, now it's time to put that power to the ground. Call Kelly at BMR and he will explain in great detail everything you need to complete your set up. With the LCA's you should also get the adjustable relocation brackets, there are three different setting so you can adjust to your preference. Hell, people get wheel hop with regular GT's....After the power you added yours must be ridiculous.
Old 05-12-2015, 10:20 PM   #5
Hell yea sounds awesome! Will def so that! And Yea I've spent way too much money on this ****ing car lol........ And thanks for the help I'll Def do that! Yea I Def need some more traction lol...
Old 05-13-2015, 04:22 PM   #6
Also if I Change my Control arms wouldn't I have to do a realignment?
Old 05-13-2015, 07:27 PM   #7
I didn't have to, I just adjusted the panhard bar to make sure the axle was centered. Anything up front you probably have to get an alignment, but rear I was good or I think I am, ha ha.....
Old 05-14-2015, 12:59 AM   #8
Right, Yea I planned on just getting the rear upper and lower control arms
Old 05-14-2015, 03:16 PM   #9
tj@steeda's Avatar
You can also check out these beauties:
Steeda 2005-14 Mustang Billet Rear Lower Control Arms - Made in USA 555-4405 | Free Shipping!
Note: 555-4406 recommended for 500+ horsepower applications. Slight increase in NVH will result from this part.
U.S. Patent Pending
Product Benefits
Eliminates wheel hop, improves traction.
Super strong billet construction.
Lighter than stock and competitors arms - reduced unsprung weight.
Used on the fastest production built Mustangs
We use these on most of our high HP vehicles ... you will be very happy with them.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
Win A $300 Gift Card
tj@steeda is offline   Reply With Quote
Old 05-14-2015, 05:02 PM   #10
Hell yea ill Def check these out thanks for the recommendation man
For Sale: Bmr upper control arm, lower control arms and relocation brackets blacked out gt Mustang Parts for Sale and Wanted 26 05-30-2014 10:04 AM
Factory speed control or dealer speed control (cruise control) Otlaw80 1979-1995 Mustang GT 6 08-18-2011 08:42 PM
Control arm bolts? Tbird232ci 1979-1995 Mustang GT 2 03-19-2006 08:33 AM
upper/lower control arm install chipshot101 1996-2004 Mustang GT 4 07-27-2004 08:18 PM
Lower control arm bolts Monkey Pre-2005 V6 Mustang 1 07-15-2003 11:37 AM
11:33 AM
