Solutions to wheel spin - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Roush Mustang
Old 07-26-2015, 08:03 AM   #1
Rosariors3's Avatar
I started a thread on who I should get my mods and tune from. From opinions and my own research I decided to go with vmp tuning. Now I see a lot of conversations on putting the power to the pavement, wheel spin etc. I'm running on cooper rs3 20's for my street tire. From what I gather this is "not gonna cut it" . So my ? Is what would be a good street tire mod combo? Do I need to change my gear ratio, differential? I want to keep my car a daily driver so with gas consumption and ride quality in mind what would be the best setup for me? I just want to enjoy cruising my awesome mustang but if a situation came for a street Race I want to eat up my opponite😈😈
Rosariors3 is offline   Reply With Quote
Old 07-26-2015, 10:52 AM   #2
Ubnbit's Avatar
What is your gear ratio now? I'm pretty interested in this thread. I have subscribed. I know most will say to change suspension and go with Michelin pilots or something comparable. Since I have changed my throttle body, I can break loose in 1st-5th it seems almost at anytime. I've done a lot of suspension already and will get new tires soon. I hope that fixes it.
---------- Post added at 12:52 PM ---------- Previous post was at 12:51 PM ----------
And, you can't talk street racing. It's very dangerous and frowned upon. Not to mention. Illegal. Lol
Old 07-26-2015, 11:59 AM   #3
Rosariors3's Avatar
3:73
Old 07-26-2015, 12:02 PM   #4
Rosariors3's Avatar
I have a roush stage 3... Not sure what the suspension setup is but I would imagine that I don't need to go with a diff setup.
Old 07-26-2015, 12:06 PM   #5
Ubnbit's Avatar
That's what I thought too lol.
Old 07-26-2015, 05:01 PM   #6
I have a 14 Stage 3 as well. Actually Roush does not upgrade all your suspension, so you probably have to alter somewhat. You can see my mods in signature, they helped a ton!! but traction is still an issue. Not nearly as bad as before, but still nothing to brag about. i think the BMR LCA's with relocation brackets helped a lot. When I did that I also got the BMR sway bar and panhard. A t the end of the day 20's are not the best wheel/tire combo if you are looking to hook. If you do end up switching wheel set up, just make sure what you get will fit over your big brakes
Phase 3 upgrade including CAI, Fuel pump voltage regulator, (648rwhp), 582 torque, Kooks LT headers with off road H pipe, Vossen CV3's, ID1000's, Steeda Heat Exchanger, BMR LCA's,relocation brackets, adjustable Panhard bar, Rear sway bar, Steeda Aluminum driveshaft, X-brace, Differential cover, torque box brace/frame rails, Shelby trans cooler, Mcleod RST clutch/lightweight steel flywheel w/SS clutch line, RP fluids, whiteline transmission bushing,MGW race spec short shifter,Ford racing twin 65mm throttle body, Pro Dyno tuned
jamyzd30 is offline   Reply With Quote
Old 07-27-2015, 10:42 AM   #7
The stock Pirelli are not very sticky. I even went to 285/40-19's and not much improvement. Just had rear wheels widened to 10.5 and will be running 305/30-19 michelin pilot sport PS2's. I have a track pac with ford Whipple supercharger and have most rear suspension mods.
Cobrakit is offline   Reply With Quote
Old 07-27-2015, 12:17 PM   #8
Fabman's Avatar
Relocation brackets....if the car is lowered at all the geometry will be effed up.
Make sure at ride height the lower control arms are flat to the ground or point slightly up to the front of the car. Unless this is right, nothing else will ever be no matter how much money you throw at it.
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 07-27-2015, 12:56 PM   #9
Strange Mud's Avatar
The problem is 600+ hp on rear wheel drive only car.
Old 07-27-2015, 01:05 PM   #10
Fabman's Avatar
I must have missed that part. I have over 600 as well and pretty much nothing but slicks will solve that....but like I said, if the rear geometry isn't right, nothing else will be either.
Tuned by AED
Old 07-27-2015, 01:08 PM   #11
Fabman's Avatar
I don't see that the OP has 600 rwhp....did I miss something?
Tuned by AED
Old 07-27-2015, 02:23 PM   #12
tj@steeda's Avatar
I would be happy to put you in contact with our suspension build experts according to your budget, driving style & long-term goals.
It is difficult to tell you exactly what you need without knowing all of the other details, like mentioned above.
You can reach me at tim@steeda.com if you would like to be contacted by a build expert & also work in forum pricing.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 07-27-2015, 02:50 PM   #13
this is where I came up with it. I'm assuming on the HP # but think I'm correct.
Old 07-27-2015, 03:56 PM   #14
Fabman's Avatar
I'm only guessing here but I'd be surprised if it was really 600 rwhp.
Most of the after market builders use crank HP because its a bigger number. Basically, subtract 100 from crank to get rear wheel HP and it gets you close.
Or do the math and it's crank X .85 and you get 510 rwhp.
Tuned by AED
Old 07-27-2015, 08:24 PM   #15
Rosariors3's Avatar
The kit says 675 Hp flywheel. I'm thinking itl b high 5 at the wheel.
Old 07-27-2015, 08:29 PM   #16
Fabman's Avatar
Thats impressive...I keep thinking 3 valve because that's all there was for so long....the Coyotes are way more potent.
Tuned by AED
Old 07-27-2015, 08:31 PM   #17
Fabman's Avatar
573.75 rwhp...not too shabbly.
Tuned by AED
Old 07-27-2015, 08:34 PM   #18
Rosariors3's Avatar
The car as it sits is 540 t the crank. I can't imagine what it will feel like after the tune.
Old 07-27-2015, 08:43 PM   #19
Rosariors3's Avatar
Fabman what do u have as far as year model and upgrades?
Old 07-27-2015, 08:50 PM   #20
Rosariors3's Avatar
Nvm I had to select the full website tab to look at the avatars. I c what u have now
Old 07-27-2015, 08:53 PM   #21
Rosariors3's Avatar
Fabman u have a hell of a car!!!
Old 07-27-2015, 09:30 PM   #22
Fabman's Avatar
Its just an old obsolete 3 valve.
Tuned by AED
Old 07-27-2015, 09:37 PM   #23
Ha, obsolete that's funny. I think it's far from it.
Pick your poison.
Recon is online now   Reply With Quote
Old 07-27-2015, 09:40 PM   #24
Fabman's Avatar
Pick your poison.
Visit some of the Coyote forums...I might as well be driving a model A
Tuned by AED
Old 07-27-2015, 09:42 PM   #25
Still better looking than them, to me at least. Then again you could always coyote swap it. And build some ridiculous set up. Twins and supercharged and nitrous.
Pick your poison.
Old 07-27-2015, 09:46 PM   #26
Fabman's Avatar
Pick your poison.
It already makes more power than any street tire can handle.
I am lowering the boost and going road racing with it
Tuned by AED
Old 07-27-2015, 09:50 PM   #27
Probably the biggest reason I think it's the coolest car on the forum. You run what 10s in the quarter? Then pullie swap and then fly through corners. Basically the car is built for both, or at least do both.
Pick your poison.
Old 07-27-2015, 09:52 PM   #28
Fabman's Avatar
Pick your poison.
10.22 @ 135 and yes, its got konis on it
Tuned by AED
Old 07-27-2015, 09:54 PM   #29
Is the swap done on it?
Pick your poison.
Old 07-27-2015, 09:54 PM   #30
Fabman's Avatar
Tuned by AED
Old 07-27-2015, 09:58 PM   #31
Fabman's Avatar
Pick your poison.
Almost.
I hope to make sept 19th at Thunder Hill
Tuned by AED
Old 07-27-2015, 10:01 PM   #32
Thunder hill, is that a strip or course? Sorry, I'm on the other side of the country; so it's basically a name to me.
Pick your poison.
Old 07-27-2015, 10:03 PM   #33
Fabman's Avatar
Pick your poison.
Big azz road course....and thank you for the kind words.
Tuned by AED
Old 07-27-2015, 10:05 PM   #34
I need to check it out. I'm hoping that I can make the event at the Corvette track in Bowling Green in September. Car is a long way before it's ready. Definitely needs a few more mods before I'd take it out on the track.
Pick your poison.
Old 07-27-2015, 10:08 PM   #35
Fabman's Avatar
Start at around 14.00
https://youtu.be/DC3fgT7Uxa8
Tuned by AED
Anyone else have problems with wheel spin? dark mod General Mustang Discussion 22 10-10-2012 02:58 AM
5.0 Tuning Solutions Thomas91169 1979-1995 Mustang GT 13 12-24-2007 11:09 AM
Bigger and longer lasting solutions rolled up into one (pun intended) wiarumas The Bar 4 08-09-2007 02:55 PM
poor gas mileage...general solutions tedness The Bar 23 08-31-2005 09:55 AM
06:36 AM
