Coyote with 675 horse - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Roush Mustang
Old 08-08-2015, 01:27 PM   #1
Rosariors3's Avatar
ok so I installed all the necessary parts and the tune from vmp. Wow this car is a blast, woke right up. My next upgrade will prob be a short shifter and driveshaft. Can this coyote handle the 675 horses that vmp claims after installing this "power package". I'm happy with the car the way it sits as far as power. I have 5800 miles on the car.
Rosariors3 is offline   Reply With Quote
Old 08-08-2015, 03:25 PM   #2
LaserRed99's Avatar
Wow that's a ton of power. Is the motor built up? I'm not a coyote expert, but isn't that a bit beyond the safe limits if it's a stock motor?
'03 Mach 1 5spd
Fully forged Manley rods/pistons, Cobra crank, ARP hardware, 8.5:1, Procharger P1SC w/ intercooler, AFM power pipe, 60# injectors, 03/04 Cobra tank with dual fuel pumps, Kenne Bell Boost-a-Pump, O/R X pipe and Flowmasters, Exedy stage 3 clutch, Steeda Tri-Ax, Front and rear upper + lower control arms, Ford Racing springs, Bob Monks tune 448 rwhp @ 9 PSI
LaserRed99 is offline   Reply With Quote
Old 08-08-2015, 03:26 PM   #3
Rapinator126's Avatar
It's 675 at the crank so probably about 580-610 at the tires depending on the dyno.
Which is fine
Rapinator126 is online now   Reply With Quote
Old 08-08-2015, 10:23 PM   #4
Rosariors3's Avatar
Which is fine
rap watr u putting down on the tires?
Old 08-08-2015, 10:24 PM   #5
Mid 700's
Old 08-08-2015, 10:30 PM   #6
Rosariors3's Avatar
Mid 700's
hahaha wow,, that's impressive and your doing that with stock motor?
Old 08-08-2015, 10:30 PM   #7
No its built
Old 08-08-2015, 10:35 PM   #8
Rosariors3's Avatar
when did u decide to build? what was whp at the time when u thought u needed more but you knew you had to build?
Old 08-08-2015, 10:37 PM   #9
Stock motor let go at 611 at the tires. Had a lot to do with a distribution issue and 650 ft-lbs at 2800rpms
Old 08-08-2015, 10:44 PM   #10
Rosariors3's Avatar
wow!! do u think the tune had something to do with that? don't wanna b that guy with all these questions but this is what im afraid of. I mean if something were to go wrong I would prob go with the aluuminator but id rather not. money doesn't grow on trees. just trying to get an idea of what my limit for modding is.
Old 08-08-2015, 10:47 PM   #11
No it wasn't the tune. It was just abuse and distribution problems.
You will be good for low 600's with a good tune on stock motor.
Old 08-08-2015, 10:54 PM   #12
Rosariors3's Avatar
one more thing!!! when I got the car and first drove it I was ecstatic, couple months later wanted more and I now am pleased. is it me only that the more power I get the more I want? do u feel the same? I mean u have 700 but u have a built motor and could prob squeeze more. do u c urself adding more?
Old 08-08-2015, 10:58 PM   #13
It is addicting, most people always want more. Jusy have to find what makes you happy with it. Once you get in the 600+ range and can hook up it makes for a fun street car.
I will be going for 900's
Old 08-08-2015, 11:06 PM   #14
Rosariors3's Avatar
thanks rap. I love the car and I def want to do more. got another baby on the way so it will have to wait, and for the future I might hit u up wit more questions and advice.
Old 08-08-2015, 11:08 PM   #15
Anytime bud.
Old 09-03-2015, 09:05 AM   #16
MADSCOTSMAN's Avatar
I have the same kit on my 12' RS3 and must say it is RE-diculously faster now. I was thinking about a different shifter and talking with my service guy about them. He thought they were a waste of $$$ and has a lot of people paying to have them removed shortly after paying for the installs (take his opinion with a grain of salt). I was wanting to remedy the occasional grinding and resistance of the car going into gears. He recommended I try a bracket first so I ordered the Barton 2 Post bracket and had it installed. The grinding is gone for me now and shifting feels more "notchy" and solid. Best mod I have done other than the VMP phase 3 kit. Next mod will be some new Continental DWS tires to replace the crappy Cooper's
MADSCOTSMAN is offline   Reply With Quote
Old 09-10-2015, 09:05 AM   #17
Your service guy is an idiot if he didn't recommend changing the shifter....The factory one is complete garbage. I think the MGW race spec short shifter was hands down the best mod I have done, and I have around 7k in mods. Howver, since you already got the bracket, and if you are happy with it, no need to change. The only aftermarket shifters that people may have had removed was the hurst ones. The MGW is great and Barton has tremendous reviews as well.
Phase 3 upgrade including CAI, Fuel pump voltage regulator, (648rwhp), 582 torque, Kooks LT headers with off road H pipe, Vossen CV3's, ID1000's, Steeda Heat Exchanger, BMR LCA's,relocation brackets, adjustable Panhard bar, Rear sway bar, Steeda Aluminum driveshaft, X-brace, Differential cover, torque box brace/frame rails, Shelby trans cooler, Mcleod RST clutch/lightweight steel flywheel w/SS clutch line, RP fluids, whiteline transmission bushing,MGW race spec short shifter,Ford racing twin 65mm throttle body, Pro Dyno tuned
jamyzd30 is offline   Reply With Quote
Old 09-10-2015, 01:20 PM   #18
Rosariors3's Avatar
Let me know how u make out with the tires. Also if u get any other mods let me know as well. Thanks
I might not know as much as you but i know how to drive better than you!!!
675 VMP kit Lildude Roush Mustang 49 08-14-2015 11:33 AM
how much horse power mtchll50 1996-2004 Mustang GT 14 07-09-2004 12:09 AM
Mass murderer horse and kamikaze buzzard WhiteStang99 The Bar 6 06-21-2004 02:56 PM
Guy in central area check this out! (HORSE ESP) Zim Regional Mustang Discussion 5 01-26-2004 11:27 PM
Running Horse Decal? KrazyPony The Bar 2 12-21-2003 10:02 PM
03:17 AM
