Who manufacturers Roush brake set - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Roush Mustang
Old 05-23-2016, 06:40 PM   #1
2011 Kona Blue's Avatar
My father decided to add this brake set to his 5.0. I was just wondering who manufacturers the brake kit? Is it Brembo, Wilwood? They have Roush name on it and how do they compare to the 4 piston Brembo brake set?
2005 - 2014 Mustang Black 4 Piston Brake Kit w/ 1 pc Rotors
Just a near stock 3.7
Old 05-23-2016, 06:43 PM   #2
It was Alco, but not sure if they still make them.
Old 05-23-2016, 06:45 PM   #3
Rosariors3's Avatar
Stoptech
I might not know as much as you but i know how to drive better than you!!!
Rosariors3 is offline   Reply With Quote
Old 05-23-2016, 08:03 PM   #4
I had Brembo's on my 13 Roush and on my 2014 I have the Roush brake package, both 4 piston. The 2014 stops better for sure, no doubt. My 14 does have slotted rotors which I doubt changes much. Neither brake package stopped very well going 140+.....The 4 piston brakes up front are sufficient for sure, I have little brakes in the rear. I can only imagine that the 6 piston ones are far better! Anyways for normal street driving both packages were good, I'd say brembos were more dusty and didn't stop as good as Roush ones.
Phase 3 upgrade including CAI, Fuel pump voltage regulator, (629rwhp), 543 torque, Kooks LT headers with off road H pipe,ID1000's, Steeda Heat Exchanger, SCT tuner with custom Pro Dyno tune, BMR LCA's, BMR relocation brackets, BMR adjustable Panhard bar, BMR Rear sway bar, Steeda Aluminum driveshaft, Steeda X-brace, Steeda Differential cover, Steeda torque box brace/frame rails, Shelby trans cooler, Mcleod SS clutch line, RP fluids, whiteline transmission bushing insert and MGW race spec short shifter.
jamyzd30 is offline   Reply With Quote
Old 05-24-2016, 07:50 AM   #5
So the Roush brakes set is good, thats good to know. My father also added the stage 2 blower, 625 HP
Old 07-26-2016, 12:39 AM   #6
Hi, as above Roush use's Stoptech calipers with Roush logos and Stoptech rotors on the front and on the rear they use the stock Mustang caliper (painted to match the front) with Stoptech slotted rotors.
I had my 2011 Roush upgraded to these by the dealer and I'm very happy with the performance and the looks.
Forgot to add they use the Stoptech pads as well.
Fawls is offline   Reply With Quote
brake set up track days cone carver 1996-2004 Mustang GT 11 02-13-2016 10:02 PM
Parts Manufacturers!! Kustumb General Car Discussion 0 01-17-2014 12:13 AM
Small Custom Parts Manufacturers Thread Kustumb The Bar 0 01-15-2014 06:39 PM
Roush Mustang GT - Current Mustang :: 2003 Ford - Roush GT - Roush Stage 2 Tib Member Garages 0 06-15-2011 12:01 PM
08:50 AM
