Front end poping noise. - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Roush Mustang
Old 08-14-2016, 08:59 AM   #1
Hello,
This is my frist post on the forum. We have bought a 06 stage 3 Roush. Had it for about a year now. It has always had a bit of a poping or creaking noise mainly the drivers side. Sounds like it's coming from the supension. It's has the blue Roush struts and springs. Only thing in have done is jacked it up and sprayed a little white grease where the bottom coils of the springs rub together. The car is my wife's and I don't normally drive it. But I get to do the maintenance on it. Anyone have any ideas or similar issues?
When we both the car I found the top camber bolt losse on the driver side, but have had them replaced and alignment done.
Thanks for any comments
varoush06 is offline   Reply With Quote
Old 08-14-2016, 11:41 AM   #2
Mile high JDF's Avatar
Sounds like a ball joint going bad. Does it only do it when steering or going over bumps?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-15-2016, 07:01 AM   #3
Thanks,
Almost seems like the slightest movement or bump. Backing out of the garage and idling down the driveway you can hear it. Just wondering if had something to do with the Roush suspension.
Old 08-15-2016, 07:16 AM   #4
jkeaton's Avatar
Ball joints most likely. They will pop and squeak when bad. Also tie rods.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 08-15-2016, 08:03 PM   #5
olerodder's Avatar
Region: Oregon
Or it could be strut mounts....
Old 08-20-2016, 03:05 AM   #6
Ok
I'll check out the ball joints and strut mounts. Thanks for the input.
Old 08-22-2016, 06:41 PM   #7
FastFord13's Avatar
Could be lower control arm hydra bushing
Samsung Galaxy S6 Edge.
Old 08-28-2016, 09:28 PM   #8
Hampton CIT's Avatar
Center nut in your shock tower for a box of doughnuts. Been there and done that myself.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
For Trade: My 2014 V6 Front End for your 2011-2012 GT Front End CodyC Mustang Parts for Sale and Wanted 3 03-15-2015 09:42 PM
86 front end into an 89 front end Beatjunkiexorge 2.3 Mustang 1 05-18-2013 08:07 PM
SR lowering spring poping sound rebeltx 2011-2014 V6 Mustang 6 02-24-2013 11:51 PM
Poping in front end 03 gtmustang 1996-2004 Mustang GT 5 07-17-2012 08:36 AM
help loud poping Supersnake4.6 General Mustang Discussion 8 09-02-2011 03:10 PM
05:38 PM
