2016 Stage3...Launch in 2nd?? - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Roush Mustang
Old 08-15-2016, 12:22 PM   #1
Hi all!!
Trying to get a quicker 0-60...to that end, is 2nd gear launch OK for this purpose?
Launching in in 1st seems like a waist of time with 3.73's and this much power. Also, I can only get traction control to not kick-in in Race Mode, Sport mode still bogs the car down in 1st.
Also, if others ARE launching in 2nd, at what rpm are you launching on street tires?
Over all... it just seems like I'm not really getting anywhere and making progress till I'm in 3rd.
This is still better than my 11' gt500 that I COULDN'T shift from 1st to 2nd at any fast pace but...there I had 3.55's and quite a bit less power.
Any tips?? What's it gonna break first doing this?
SniffinPopRocks is offline   Reply With Quote
Old 08-16-2016, 05:57 AM   #2
MADSCOTSMAN's Avatar
I'm getting ready to work up the nerve to take my Stage 3 to the track one of these days (2012 stage 3 with VMP's phase III package). I just installed a dual stage shift light with the launch feature. An article I found online reviewing a Roush stage III indicated the best launch that the author had found was 2500 RPM, then dump the clutch, but he was also in 1st gear, with traction control turned off. I'm not sure if that is going to work, but that's where I set my launch RPM for now. But I'm with you, I don't want to break or tear the car up, just enjoy the acceleration and speed.
MADSCOTSMAN is offline   Reply With Quote
Old 08-30-2016, 01:28 AM   #3
Launching in 2nd will give you a bad 60 ft time. Let more air out of your tires. You most like need wider tires also. My factory Roush wheel were only 9.5 and tires 275's. Not near enough tire for the power. Now I'm running 305's on 10.5 wide wheel. It hooks WAY better now, not perfect though. I've been told launching in 2nd is harder on clutch also. Just work on figuring out 1st, u won't be in it long but 1st gear is always there for a reason.
Phase 3 upgrade including CAI, Fuel pump voltage regulator, (648rwhp), 582 torque, Kooks LT headers with off road H pipe, Vossen CV3's, ID1000's, Steeda Heat Exchanger, BMR LCA's,relocation brackets, adjustable Panhard bar, Rear sway bar, Steeda Aluminum driveshaft, X-brace, Differential cover, torque box brace/frame rails, Shelby trans cooler, Mcleod RST clutch/lightweight steel flywheel w/SS clutch line, RP fluids, whiteline transmission bushing,MGW race spec short shifter,Ford racing twin 65mm throttle body, Pro Dyno tuned
jamyzd30 is offline   Reply With Quote
Old 04-30-2017, 01:58 PM   #4
EastTNMustang's Avatar
Reviving an old thread...what did you figure out for launching?
EastTNMustang is offline   Reply With Quote
making my 02 stage 1 a stage3 memo232 Roush Mustang 18 03-01-2012 09:38 AM
nice launch Warfire80 The Bar 6 05-21-2004 10:46 AM
Drag Launch Springs 02whitestang Pre-2005 V6 Mustang 1 11-22-2003 01:41 PM
.. Official Office 2003 System Launch Thread ...? ..... Yeah Laser02 The Bar 4 11-06-2003 02:14 PM
06:32 AM
