3.4" pulley! - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Saleen & SMS Mustang
Old 01-13-2012, 01:26 PM   #1
syrupsaleen's Avatar
3.4" pulley!
I'm looking to get the 3.4" pulley for my 06 s281 and would like to know if there's anybody running that size pulley and what's the rest of you're set up like and how's it running? Really need some advice on what all I need and what I should go with thanks!
syrupsaleen is offline   Reply With Quote
Old 01-13-2012, 01:56 PM   #2
Re: 3.4" pulley!
are you talking about supercharger pulley related or what exactly? If its supercharger related and it will raise the boost its best to get it checked, if it raises the boost by more than 1-2psi you will probably require a re-tune to be safe else you risk blowing up the car~
the limit on those motors isnt much unless its the S281-E, otherwise try not to go past 450rwhp.
Old 01-13-2012, 02:26 PM   #3
Yes I'm talking about the supercharger pulley. And I am gonna get it re-tuned. I was also wanting to know what all I have to change/upgrade if I go with a 3.4" pulley?
Old 01-13-2012, 08:04 PM   #4
S281's Avatar
Re: 3.4" pulley!
If you already have the 39lb injectors, you need a boost a pump or fuel pump upgrade and a tune. What size pulley are you running now?
S281 is offline   Reply With Quote
Old 01-13-2012, 08:52 PM   #5
I do have the 39lb injectors. And I have the 3.875" pulley the one that comes with the 475hp upgrade kit.
Old 01-13-2012, 08:57 PM   #6
S281's Avatar
Re: 3.4" pulley!
Then you just need fuel pump or BAP and tune for the 3.4 and your good to go.
Old 01-14-2012, 09:14 AM   #7
Awesome thanks! @spectorV why can it only handel that amount of hp?
Old 01-14-2012, 09:15 AM   #8
Las0mbra's Avatar
That's just how much the engine itself can take before it goes kaboom...
Old 01-14-2012, 09:47 AM   #9
S281's Avatar
Re: 3.4" pulley!
450 whp seems to be the number. There's alot of guys running more with no issues as long as you have a good tune.
Old 01-14-2012, 09:51 AM   #10
Well that's not good. How much hp do yall think I'm gonna put down since I have the 475hp upgrade and if I add the 3.4 pulley?
Old 01-14-2012, 11:58 AM   #11
S281's Avatar
Re: 3.4" pulley!
I'm running a 3.4 pulley and am probably around 450 whp. 475 kit is crank hp.You'll be fine with the 3.4. Like I said before there's lots of guys running 3.0,2.8 with no problem. If your worried about it go to the 3.6 then you just need a tune. Have you done the vacuum line upgrade? it makes a big difference when you see boost.
Old 01-14-2012, 12:34 PM   #12
No I haven't unless it has already been done. Is it easy to install and where can I get it?
Old 01-14-2012, 01:12 PM   #13
S281's Avatar
Re: 3.4" pulley!
http://
That's the u shaped line on the back passenger side of the s/c.
Old 01-14-2012, 04:19 PM   #14
I found it and my car does not have it like the pic shows. What exactly does it do if you hook it up like that?
Old 01-14-2012, 04:34 PM   #15
S281's Avatar
Re: 3.4" pulley!
It gives you boost sooner. Now you dont get boost till WOT. Give it a shoot, it'll cost $10 for a piece of hose a tee and cap.
Old 01-14-2012, 05:08 PM   #16
Cool I'm gonna try it. How much boost should I get with the 3.4 pulley?
Old 01-14-2012, 05:10 PM   #17
S281's Avatar
Re: 3.4" pulley!
Around 9 lbs
Old 01-14-2012, 05:31 PM   #18
Nice! About the amount of hp the motor can handel I guess there's nothing you can upgrade or change to where it could hold more power?
Old 01-14-2012, 05:37 PM   #19
S281's Avatar
Re: 3.4" pulley!
You have to go to forged bottom end. Something else you need I forgot to mention, is a SCT tuner.
Old 01-14-2012, 06:04 PM   #20
Okay yea I'm getting the tuner with the JLT cai.
Old 01-14-2012, 06:14 PM   #21
S281's Avatar
Re: 3.4" pulley!
Then your set, the tuner the most expensive part. Hopefully they've changed the JLT Series 3 heatsheild. I had to do some cutting on mine to get the hood to close.
Old 01-14-2012, 06:35 PM   #22
Oh really... Hopefully they have changed. I guess you had to cut it at the top?
Old 01-16-2012, 08:45 PM   #23
I guess since the motor can only handel about 450rwhp the motor does not have forged pistons?
Old 01-16-2012, 08:54 PM   #24
Re: 3.4" pulley!
I would recommend against capping the boost bypass. Other s/c cars have had issues with spikes causing other issues.
Old 01-16-2012, 09:04 PM   #25
S281's Avatar
Re: 3.4" pulley!
No forged internals.Your not capping the boost bypass. If you call Brenspeed or any tuner that specialize in Saleen blowers for a tune one of their questions will be, have you done the vacuum line upgrade?
Old 01-16-2012, 09:42 PM   #26
I'll have to check into the vacuum line some more then and see what everybody says.
Old 01-16-2012, 10:15 PM   #27
S281's Avatar
Re: 3.4" pulley!
http://http://mustangforums.com/foru...grade-kit.html
Old 01-18-2012, 07:23 AM   #28
Gibby's Avatar
Your also gonna need a cold heat range spark plug. I have the 3.6 and it's amazing with the vacuum line upgrade
Gibby is offline   Reply With Quote
Old 01-18-2012, 08:11 AM   #29
Do I need that plug for the vacuum upgrade or for the pulley?
Old 01-18-2012, 08:22 AM   #30
Gibby's Avatar
For any pulley smaller than 3.6
Old 01-18-2012, 09:09 AM   #31
Do I need to buy the vacuum upgrade kit or just buy the parts myself?
Old 01-18-2012, 09:46 AM   #32
Gibby's Avatar
It's just vacuum lines. Either way will work. Call the guys at brenspeed, they have awesome tech support
Old 01-18-2012, 09:54 AM   #33
Re: 3.4" pulley!
GT mustangs generally can take more than 450rwhp but I would try not to go past that for my daily driver. Maybe now and again at the track stick in a more aggressive tune or something, better to be a bit safer than to risk blowing up the motor since you engine is not built to take as much abuse. Just a safety net.
My friend's 06 GT has 480rwhp and its fine, just most say 450 is a good spot to aim for.
Old 01-18-2012, 09:58 AM   #34
Gibby's Avatar
The guys at brenspeed told me with an intake, tune, 3.6 pulley that it's a good reliable set up. They also said anything after that is just driving on narrowed time.... That is if you drive like me.
Old 01-18-2012, 10:02 AM   #35
Re: 3.4" pulley!
a good dyno tune is the most important part of course, it has to be spot on and have wiggle room
Crank pulley Sonicblue05 2005-2010 Mustang GT 2 12-29-2011 06:29 AM
Vortech S/c pulley size? 99redbeast SVT Mustang 5 11-19-2011 12:48 AM
Pulley squeal USAF_stang 1996-2004 Mustang GT 7 11-02-2011 12:27 PM
Idler pulley jwhayne0001 1979-1995 Mustang GT 10 08-25-2011 04:48 PM
Water pump pulley Carlos92 Pre-2005 V6 Mustang 6 07-04-2011 07:55 PM
11:48 PM
