slicks - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Saleen & SMS Mustang
Old 06-09-2012, 08:38 AM   #1
syrupsaleen's Avatar
slicks
Well the time has come to buy some good drag radials or slicks that I'm gonna use at the track only! What type and brand is everybody running or would recommend?
syrupsaleen is offline   Reply With Quote
Old 06-09-2012, 08:55 AM   #2
Stick with the dr's. They're a more forgiving tire to learn on.
I have had good luck with the m/t et street but the new hoosier dr is supposed to be even better. 1.6 60' is easy on the m/t.
Picking up a set of et drags and front runners today. Hopefully will have good luck on those.
Old 06-09-2012, 10:20 AM   #3
What size m/ts do you run?
Old 06-09-2012, 11:56 AM   #4
Gonna depend on what wheels you have and gears
Old 06-09-2012, 12:55 PM   #5
I have 4.10s either gonna get 15"s or 17"s
Old 06-09-2012, 01:49 PM   #6
Big difference between the two. With that much gear you'll probably want something close to 28" tall
Old 06-09-2012, 04:34 PM   #7
What size wheel would you recommend with those gears?
Old 06-09-2012, 06:25 PM   #8
The wheel size isn't going to make any difference in overall height. I run 15s personally
Old 06-09-2012, 06:45 PM   #9
I'm thinking bout getting 15's. I guess just get a radial in a size that brings it close to 28" overall...
Old 06-09-2012, 07:32 PM   #10
...that isn't a slick. You would be running a drag radial.
Old 06-09-2012, 09:23 PM   #11
Yeah I ment a drag radial. Do I need to make any changes on my rear end
Old 06-09-2012, 09:31 PM   #12
It's not the best of ideas to leave hard on the stock rear
Old 06-09-2012, 11:20 PM   #13
Do I need like a panhard bar, watts link or anything like that?
Old 06-10-2012, 08:32 AM   #14
I'd worry more about the axles
Old 06-12-2012, 07:02 AM   #15
What's your best 1/4 mile time with the m/t's
Old 06-12-2012, 08:34 AM   #16
11.9 on the et streets
Old 06-12-2012, 08:45 AM   #17
Nice! What's your rwhp?
Old 06-12-2012, 09:56 AM   #18
490
Old 06-12-2012, 11:37 AM   #19
That's good! I'm probably low 400. Just checked out some m/t's online, the one you recommend for me was it the et drag radial or et street radial?
Old 06-15-2012, 08:31 AM   #20
Anybody else have some suggestions for me on drag radials?
Old 06-15-2012, 08:48 AM   #21
Lorraine's driver
ab_mach1's Avatar
This website is referenced in one of Mustang Evolutions stickys. Good info on DRs.
http://www.stangtv.com/tech-stories/...-drag-radials/
Instagram: @ab_mach1
Old 06-15-2012, 09:49 AM   #22
Thanks ill check it out!
Old 06-15-2012, 12:22 PM   #23
Just do the street radial. You should be able to cut 1.6 60' on those with no problem
Old 06-15-2012, 01:35 PM   #24
Heck yea I'm game with a 1.6 60'
Old 06-15-2012, 04:29 PM   #25
I was cutting that on those tires and the irs
Old 06-15-2012, 04:45 PM   #26
I have a srs. Would you pay $350 for 2 mickey thompson with 70% life left?
Old 06-15-2012, 07:55 PM   #27
Depending on size they're only 200 or so a piece. Around 300 would be a better price
Old 06-16-2012, 08:30 AM   #28
They are 325/50-15 if I ran those in the back can I keep my 20's up front while running at the track?
Old 06-16-2012, 12:40 PM   #29
You could... Gonna be alot of weight to push on the front...
Old 06-16-2012, 02:04 PM   #30
Eventually I wanna get something smaller for the fronts but for now it'll have to do...
04:31 PM
