Tire Pressure - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Saleen & SMS Mustang
Old 03-25-2015, 10:30 AM   #1
Jbone007's Avatar
Tire Pressure
Any one else having issues with tire pressure, I keep getting a low tire pressure warning light. Last time it was the right front tire, took it in and it was leaking around the inside of the wheel, the tech said that there was some corrosion on the inside of the wheel causing it to leak. He removed the tire cleaned it up and it was good for about 6 weeks, now it is low again!
Jbone007 is offline   Reply With Quote
Old 03-25-2015, 10:35 AM   #2
christianh's Avatar
Yes me too. I've had tire sensor fault alarms come up since I bought the car. Goes on and off every few days. Of COURSE every time I bring it to the dealership it goes off.
Paxton Charged Unicorn
christianh is offline   Reply With Quote
Old 03-25-2015, 10:41 AM   #3
Jbone007's Avatar
At 1st I thought it was a false alarm also, I backed out of the garage and just to make sure I walked around the car and the front right tire was basically flat it had about 12PSI in it, Good thing I looked before I started driving it!
Old 03-25-2015, 10:44 AM   #4
Jbone007's Avatar
The light came on again this AM on the way into work. I did a quick walk around they all look ok but will stop by the station and check the tire pressure to make sure! I wish it would say which tire was low instead of just a general warning lol!
Old 03-25-2015, 10:49 AM   #5
christianh's Avatar
Yeah no kidding. Good luck
Old 03-25-2015, 10:06 PM   #6
Black8thElement's Avatar
Inside your driver door sill shows what your psi should be grab your gauge and check each one.
Black 2008 Decepticon GT "If it ain't hooking, it ain't booking" edition
Black8thElement is offline   Reply With Quote
Old 03-25-2015, 10:12 PM   #7
NewMtang's Avatar
GM has that and Ford or anyone one else making TMPS cannot duplicate it. Not only do the GM tell you which wheel but what the tire pressure is. Poor Mustang Owners get it in the rear end again.
Old 03-26-2015, 09:26 AM   #8
Jbone007's Avatar
Checked again this am and it was back down to 30 PSI from the 34 the night before, will take it back in to see it leaking from the same area again, may have a warranty issue with the wheel.
Old 03-26-2015, 09:29 AM   #9
Yeah i had a tire like that i just got tired of putting air it in and bought a new one
Old 03-26-2015, 09:33 AM   #10
Jbone007's Avatar
Less than 10k miles on it hope I don't have to replace it!
Old 03-27-2015, 11:36 AM   #11
Jbone007's Avatar
Just had it checked again, leaking on the inside of the wheel same area as last time Photos of tire and wheel dunked in water tank
ID:	178494   Click image for larger version
Old 03-27-2015, 12:46 PM   #12
christianh's Avatar
Ridiculous. Any insight on why it's happening?
Old 03-27-2015, 12:52 PM   #13
Jbone007's Avatar
Corrosion on the wheel or a defect in the wheel in that area causing the tire and wheel not to seal. They put sealant on the wheel again, will see how well it holds up this time.
Old 03-27-2015, 01:20 PM   #14
Jbone007's Avatar
Well just spoke with Shawn at Saleen and he said to take it back to a Ford dealer and have them take a look at it. If they (Ford) confirm that there is a problem with the wheel then Saleen will replace it under warranty!
« Hello | Saleen »
New oil pressure sending unit, still 0 oil pressure Iryan7 Pre-2005 V6 Mustang 9 07-13-2015 03:15 PM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
tire pressure ryanxup Pre-2005 V6 Mustang 3 09-30-2006 02:07 PM
ideal track tire pressure...17x9 tedness Mustang Wheels & Tires 4 10-20-2005 06:25 AM
Tire Pressure? 275x40x17 Shahrum Mustang Wheels & Tires 4 04-07-2004 08:58 AM
04:19 PM
