Anyone build a "real" 4-bolt block/4v heads BOSS? - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Boss Mustang
Old 07-22-2014, 11:39 AM   #1
Region: Oregon
If this section is only for the new DOHC Boss cars, by all means, please move this to the pushrod Boss section (if there is one). That being said, I would love to hear from anyone who has built (not bought) a true Boss engine using a 4-bolt mains Windsor block and the big valve (4 barrel) Cleveland heads.
Any dyno sheets, driving impressions, tips/tricks/advice would be greatly appreciated. Did you boost it? Daily driver or track application? Detailed pictures of the build would be awesome.
I really like the ingenuity behind the actual Boss motors. And I would love to build one some day. I know that there are better aftermarket heads these days, but I want to build a Boss, and would appreciate hearing from someone who has already built one.
My wishlist for the project includes either a Ford Racing or Dart Iron Eagle 4-bolt block, forged rotating assembly, and Australian Ford Parts or CHI aluminum big valve Cleveland heads set up for the Windsor block. Custom grind cam, lightweight valvetrain. I haven't really delved too deep into particulars because I haven't heard from anyone who has done it. What they used, what worked for them.
I want to build a track only car based on a SN95 convertible with a Boss 302 pushrod five-oh. There never was a Boss model SN, so that is why I think it would be a perfect candidate for a real Boss motor. I would probably try get as much out of it as an all engine n/a build first, then (later) swap pistons/cam and add a Whipple.
Thoughts? Comments? Concerns?
DavidBoren is offline   Reply With Quote
Old 07-22-2014, 11:58 AM   #2
Region: Oregon
I should also note that the AFP heads have narrow intake ports and closed chambers. And the CHI heads also have a smaller intake port cross section. Both of these heads are still too much head for a 302ci engine, but they are taylored to work better than a set of junkyard 4v Cleveland heads. They can also be ordered with the Windsor block water passages.
Australian Ford Parts 4v heads:
[URL="http://www.ausfordparts.com/afd4v.html"[/URL]
CHI 4v heads:
[URL="http://www.chiheads.com.au/product-category/heads/ford-cylinder-heads/4v/"[/URL]
And from everything I have ever read, it is better to go with big heads and a small cam, than a big cam and small heads. Plus, the big heads will allow for awesome performance in the future if I add a supercharger.
Old 07-22-2014, 01:29 PM   #3
badsheep5.0's Avatar
CHI 4v heads:
I do believe you need to by my coworkers 95 vert so we can do a coupe / vert sn95 boss build
badsheep5.0 is offline   Reply With Quote
Small block big block discussion @ work ReggStang 2005-2010 Mustang GT 6 07-15-2012 03:16 PM
small block/ long block blackGT91 1979-1995 Mustang GT 15 05-14-2012 09:21 PM
5.0 block vs 4.6 block 98RedGT 1996-2004 Mustang GT 4 06-13-2011 12:03 PM
Will a 3.8 cougar head bolt up to a mustang block? ASSEMbler Pre-2005 V6 Mustang 2 12-03-2003 08:38 AM
06:29 PM
