Trans problem - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > Boss Mustang
Old 08-27-2014, 02:13 PM   #1
Nickboss302's Avatar
Trans problem
Any one else get blocked out of 2nd at a high rpm
Nickboss302 is offline   Reply With Quote
Old 08-27-2014, 06:41 PM   #2
Black12's Avatar
About 99% of all MT82 owners. Sorry, but shifting at high RPM is not it's strong point.
Black12 is offline   Reply With Quote
Old 08-27-2014, 07:31 PM   #3
No way to fix that problem huh
Old 08-27-2014, 07:32 PM   #4
Do you know of any way to fix that
Old 08-27-2014, 07:44 PM   #5
Boss949's Avatar
Trans problem
MT-82 is known for high rev lockout of 1-2. Or 3-4. It's a geometry problem due to remote shifter design.
Here are 3 things that I did and I rarely, if ever get locked out.
1. MGW short throw shifter. also get the composite shift knob from them.
2. Whiteline Transmission bushing
3. CHE K Member Brace with V8 torque limiters. http://www.cheperformance.com
2013 Boss, PW, Recaros, 3:73, AED tunes, Airaid CAI, MGW, Hotchkis springs, LCA's, Whitline Relo and Trans Bushing, Griggs Torque Arm, CHE K Member Brace, '13GT500 Quad A/B's, JLT Oil Separator Kooks 1 3/4" LT's O/R X pipe and other stuff.
Boss949 is offline   Reply With Quote
Old 08-27-2014, 08:00 PM   #6
Thanks bro
Old 06-09-2015, 05:22 PM   #7
Blowfish Trans support assemble.
Waterboy2k is offline   Reply With Quote
Old 06-09-2015, 05:54 PM   #8
Famine's Avatar
Region: South Dakota
I have been doing ok with just the Barton bracket. I plan on the steeda transmission bushing as well. I just hate the pedal to the ground crap.
Famine is offline   Reply With Quote
Old 06-13-2015, 02:28 PM   #9
jande063's Avatar
Motor mounts will solve the problem. This is not a problem with the transmission. The shift problem is just a symptom of the poorly thought out mounts for the engine and transmission. Steeda sells stiffer motor mounts, or you can buy a second set of factory mounts, drill them, and inject high durometer poly. A shifter does nothing to solve the actual problem, just bandages the symptoms.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 06-24-2015, 09:29 AM   #10
GRREEN's Avatar
This makes sense, as my manual trans 2013 V-6 mustang shifts perfectly
all the way up to redline in any gear.
GRREEN is offline   Reply With Quote
Old 08-01-2015, 08:44 PM   #11
clwalls's Avatar
Only time I have ever been locked out is at 8k trying to go into 4th. From 1-2 shift at 7-7500 all the time no problem. Have you had the car tuned and had the skip a shift feature disabled?
clwalls is offline   Reply With Quote
Old 08-04-2015, 08:40 AM   #12
The MGW actually does fix the problem because it completely gets rid of the limp noodle U-joint shift linkage and replaces it with a rigid unit that stays in one spot no matter what the trans is doing.
For a trans mount fix, just install the Whiteline insert.
trans problem or tob Sonicblue03gt 1996-2004 Mustang GT 3 04-04-2012 05:45 AM
Weird trans problem, help! fast64 Pre-2005 V6 Mustang 1 11-28-2009 01:31 PM
Trans fluid pressure problem? Otlaw80 1979-1995 Mustang GT 1 05-24-2009 03:56 PM
97 Stang Auto Trans Problem Stealth Pre-2005 V6 Mustang 5 04-20-2009 07:10 AM
99 GT Auto Trans Problem hawks05 1996-2004 Mustang GT 2 02-24-2009 04:50 PM
07:35 PM
