Detonation or Not Detonation? - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 03-14-2011, 07:28 AM   #1
... that is the question...
I hear a rattle at 1400-1500 rpms gets harder to hear (I think) when the car is warmer.
sounds kinda like detonation as I have heard my car detonate, I heard it detonate over the weekend (gas....) and this is almost like it but it sounds "lower" on the motor (hear it bouncing off the ground more so) and is a bit higher pitched than the normal detonation.
I took it down from 23 deg timing to 21 deg with a different tune I have and same noise same time same amt of noise for the issue I am talking about. My normal detonation went away but the noise I mentioned above did not change.
I am thinking its not detonation, but... not sure how to rule it out other than leave it at 21 degrees and put in some race gas to ensure I have enough octane for the timing level.
It happens under normal acceleration. On WOT I hear NOTHING all seems fine.
Other thoughts are a cat going bad or something loose rattling, but I see nothing loose.
Any tips/tricks ideas etc? I want this noise at least figured out.
Thanks!
Old 03-14-2011, 11:57 AM   #2
Could be exhaust leaks. They can sound that way sometimes. Usually more when cold but worth a shot.
Alscobra is offline   Reply With Quote
Old 03-14-2011, 02:20 PM   #3
Re: Detonation or Not Detonation?
yea it wont do it while sitting still (that ive been able to make happen) so its hard to figure out....if it was exhaust it would do it sitting I would think but I cant simulate load~
Old 03-14-2011, 02:25 PM   #4
That sucks man. You may have to diag that on a dyno.
Old 03-14-2011, 02:46 PM   #5
I hope it's just a bad tank of gas.
Built 2 Last TTT
Old 03-14-2011, 04:24 PM   #6
The H-pipe on tiff's car won't exhibit ticking (from a leak) until you actually get it under load. Doesn't really do anything at idle or with a rev.
If you've ruled out detonation then it's got to be something else. What have you done differently?
Old 03-14-2011, 04:35 PM   #7
SaleenFiend's Avatar
Hmm.. that's weird. It seems like it would almost be a suspension component or some type of heat shield (or similar peice) if it's only happening when driving at that RPM.
Hit your cats with a Rubber Mallet and listen for anything odd-although, I doubt those are the problem.
Old 04-18-2011, 09:00 AM   #8
Timm04's Avatar
That's weird the same thing happening to my car did you ever figure out what it was?
Timm04 is offline   Reply With Quote
Old 04-29-2011, 10:10 AM   #9
mz98snake's Avatar
Could also be piston slap.
mz98snake is offline   Reply With Quote
Old 04-29-2011, 02:37 PM   #10
It only does it where I can hear it about 1500rpms under normal acceleration, but It does it other times (steady at given levels doesnt go away and come back) you just have to drive by a wall or something to hear it. I had my wife drive it home a while back and I heard it from behind the car easily when she drove off. Ive not changed anything in the last bit. I need to try tapping the cats with something rubber to see if I hear anything rattling around.
Ive not ruled this out, I want to get under it tomorrow and see if I notice anything obvious and tighten up the exhaust just to see if it kinda helps it etc to clue me into what it is.
It could be, but it does it even when warm just not as bad, also its not ever done this in 5 years so I dont think thats it or hope its not lol
Sorry for the delay in reply, didnt see the thread had been updated.
Old 04-29-2011, 04:18 PM   #11
mz98snake's Avatar
Mine does the same thing. Even when hot. Less when hot. Sounds exactly like piston slap.
Old 04-30-2011, 12:59 PM   #12
Pureoctane2001's Avatar
Well I had a very similar occurance with my 01. Heard a rattling noise at higher rpm about where you would shift usually. Thought it was catlitic converters at first but soon after ruled out exhaust. After that I replace the throught bearing and clutch and flywheel insert.... No luck again well upon further inspection of the car by my mechanic buddy found out the motor had been out and there was a supercharger oil sending unit mounted on the underside of the block. The rattling was due to too much gas in the cylinders being pushed into the oil. (had upgraded fuel system with no return line) this ate one or more beRings where the rods mount to the crankshaft. It's still running strong but I figured I'd give ya an idea of what I had happen Good luck
Pureoctane2001 is offline   Reply With Quote
Old 04-30-2011, 01:03 PM   #13
And also it gets quiet when the motor warms up to operating temperature. Metal expands when hot. This would prob be a worse case scenareo
Old 05-02-2011, 08:14 AM   #14
i got under there and checked all the bolts, connections, etc, noticed a little water around one of the exhaust connections, bolts were good though. The last thing I decided to check was the oxygen sensors... one of very loose, turned by hand. I had them out when they checked my A/F a while back. Gonna drive it soon to see if that was the issue
Old 05-02-2011, 09:41 AM   #15
mz98snake's Avatar
Hopefully man! I just ignore mine now. I ran it to redline racing a buddy, noise didn't get worse. It not rpm dependant in my case.
Old 05-02-2011, 09:43 AM   #16
I had the same thing happen last year and it drove me nuts...but it didn't sound anything like detonation to me...sounded like something rattling....and would get worse in the higher RPMs. I thought it was clutch related till I saw the O2 sensor.
Old 05-02-2011, 10:18 AM   #17
Hm...gonna have to check tiff's o2 sensors...didn't even think of that.
Old 05-02-2011, 11:40 AM   #18
yea hopefully that was it
04:45 AM
