My results after Dyno tune at Pauls High Performance (PHP) - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 04-22-2011, 05:55 PM   #1
drusmith's Avatar
Send a message via Yahoo to drusmith
Thumbs down My results after Dyno tune at Pauls High Performance (PHP)
575wrhp, but a long list of problems. Basically the previous owner wanted to push out large HP without any supporting mods. So he threw a KB 2.3, 60lbs injectors and boost a pump with no other mods. Boy I am glad I went to Paul's to get it checked before I really got into driving this summer.
Problems:
- Lean, lean lean, fuel is maxed out, no more to give
- Voltage drop, horrible. I saw the sheet, it sucked. KB Boost a pump plus huge stereo = no more power for fuel pump, this made my air fuel even worse.
- JTL cold air = SUCK! to big, to many bends, not enough air flow for the blower.
- Throw-out bearing gone, Clutch needs helps
- Running hot on a 40 degree day
- Replace Toe link Bars for extra support against wheel hope due to high HP
Solution:
Clutch cable/Quadrant/Wide-track kit (PHP to install 3 weeks)
Spec stage 2 Clutch (PHP to install 3 week)
Dual Fuel pump upgrade (PHP to install 3 weeks)
Steeda Intake (ordered)(PHP recommendation)
Afco Dual Pass Heat exchanger (ordered)
SCT Mass Air unit
Full tilt Boogie racing Toe Link bars (ordered)
Full tilt Boogie racing Rear Diff support bushings (ordered)
PA 170 Amp Alternator (ordered)
After all this I will be able to put 610-620 down to the ground. I will do high HP pass on the Dyno for numbers then tune it back to 580ish for reliability. It was a long day and a real eye opener. When you push this much HP, you must back it up with everything possible to protect the engine. I should have it all done by mid June.
See pictures from parts already ordered:
Name:	Deluxe Toe links.jpg
ID:	26297   Click image for larger version
ID:	26299   Click image for larger version
drusmith is offline   Reply With Quote
Old 04-22-2011, 06:04 PM   #2
65 mustangfan4's Avatar
Good luck you should have fun when it's done
65 mustangfan4 is offline   Reply With Quote
Old 04-22-2011, 07:25 PM   #3
Loc: Austin,TX
Re: My results after Dyno tune at Pauls High Performance (PHP)
Very nice Drew and even better that you are doing it the right way! Keep us posted.
Old 04-22-2011, 07:37 PM   #4
drusmith's Avatar
Thanks DDTCM! I will keep ya posted and try to document all installs with tons of pictures.
Old 04-22-2011, 07:41 PM   #5
Not a bad platform good numbers
Junior9102 is offline   Reply With Quote
Old 04-22-2011, 07:45 PM   #6
drusmith's Avatar
Thanks Junior. It will be even better after I can trust the car and its full capabilities and just have fun.
Old 04-22-2011, 07:50 PM   #7
nickysixx's Avatar
sick man, pumped for the final results
nickysixx is offline   Reply With Quote
Old 04-22-2011, 08:24 PM   #8
Brett Greene's Avatar
Problems:
Solution:
SCT Mass Air unit
I'm feeling you buddy. Had alot of similar problems. Hope you the best sounds like you know what your doing . Keep us updated
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 04-22-2011, 08:38 PM   #9
drusmith's Avatar
Thanks Brett!
Old 04-22-2011, 08:42 PM   #10
About the same situation I had. Dynoed at 593 with previous owner. 574 safely with my tuner. My boost a pump is maxed out but safe for now. Good luck bro.
Alscobra is offline   Reply With Quote
Old 04-23-2011, 07:12 AM   #11
gixxer007's Avatar
Better to find out what is needed before you did other damage also then have to fix that also.
Sounds like you will have a nice beast on your hands when its done. Good luck and keep us posted.
gixxer007 is offline   Reply With Quote
Old 04-23-2011, 08:16 AM   #12
Phil's Avatar
Still impressive rwhp number! You have one of the best tuners in the country to get everything in order for ya!!
Phil
03 Mach 1 carbed with crank trigger distributor
http://www.prbmachining-absdeletemanifolds.com/
Phil is offline   Reply With Quote
Old 05-03-2011, 09:17 AM   #13
drusmith's Avatar
Exclamation Re: My results after Dyno tune at Pauls High Performance (PHP)
New Afco Heat Exchanger installed. Very easy install. 1hour and 30min.
Name:	Heat X-changer 017.JPG
ID:	26555   Click image for larger version
Name:	Heat X-changer 018.jpg
Name:	Heat X-changer 021.jpg
Old 05-03-2011, 09:17 AM   #14
drusmith's Avatar
Finished look!
Name:	Heat X-changer 022.JPG
Old 05-03-2011, 09:20 AM   #15
Las0mbra's Avatar
Finished look!
Nice! I love the new look
Old 05-03-2011, 09:22 AM   #16
drusmith's Avatar
Thanks!
Old 05-03-2011, 09:22 AM   #17
drusmith's Avatar
Kenny Brown matrix system Installed!
Old 05-03-2011, 09:29 AM   #18
Problems:
I think the stereo is your problem....I have a 2.2L KB pushing 20 psi and well, I am only at 85% fuel pump duty cycle with a BAP. I have plenty of room to go.
It's funny, the JLT "high boost" kit is actually a restriction when you try to run over 21 psi because of the bends you mentioned. Talk about a naming fail. lol
Why dial it back? You don't drive WOT all the time...so your "number" tune will be no different than a "dialed back" tune when driving normal on the street.
Old 05-03-2011, 09:34 AM   #19
drusmith's Avatar
Pure V
I was told by the pros at PHP that after 615 to the wheels you start cracking Pistons. I want the car to last me till I die or die in it! LOL I mainly want to be safe!
I totally agree with the stereo, but this is my fun car and i GOT TO HAVE JAMS!!! I am and DJ so I got to represent! LOL
Old 05-03-2011, 09:42 AM   #20
Pure V
There are a lot of people that would disagree with that statement...but I see where you're coming from. My only question is, how often would you be seeing that 615+ hp though? I know i run a pretty aggressive tune (19* max timing) full time...and I DD my cobra...and I probably only see my 600 hp once or twice a week...
Old 05-03-2011, 09:42 AM   #21
drusmith's Avatar
The day at Paul's High Performance
ID:	26561   Click image for larger version
ID:	26563   Click image for larger version
Old 05-03-2011, 09:44 AM   #22
drusmith's Avatar
Good point!!! I just want to be safe, but then again I want to Kick *** too! HA! I wish you lived near hear! We would have a lot to talked about!
Old 05-03-2011, 09:47 AM   #23
glad you found the issues before the engine had problems. There is no point in having 615rwhp on that given dyno vs 575 on it~ if its safer and you feel better about it leave turned back a bit... its just bragging rights anyway to say you have over 600rwhp~ etc it wont matter on a daily driver that extra 30-40rwhp~
You always want some wiggle room, being AT the limit is just asking for trouble. A little bad gas and BAM trouble.
Old 05-03-2011, 09:49 AM   #24
drusmith's Avatar
Yes! Spec, thanks for the insight! i always appreciate it. You tend to keep in real! LOl
My Baby gets dropped back of next Saturday the 14th. PHP will have it for a week to upgrade the fuel system and install Stage 2 Spec clutch. And then final Dyno!
Old 05-03-2011, 10:12 AM   #25
its never a constant, just because it makes XXX hp one day the next it can be different, its not just temp its tons of factors so tuning to the limit is just a bad idea as it can change constantly. For example my MAF in cold weather is a bit on the dangerous side...
Old 05-11-2011, 01:29 PM   #26
drusmith's Avatar
New JLT straight shot CAI. Much better! I can't wait for tune next week!
Old 05-11-2011, 01:37 PM   #27
drusmith's Avatar
Kenny Brown Matrix Kit and Full Tilt Boogie toe link bars.
ID:	26786   Click image for larger version
Name:	Drew 7 final.jpg
Name:	Drew tie bar.jpg
Old 05-11-2011, 01:40 PM   #28
Lookin good man!
Old 05-11-2011, 01:42 PM   #29
Looks great Dru. Those subframes will definitely make a difference. It should feel a whole lot stiffer now.
Old 05-11-2011, 01:49 PM   #30
drusmith's Avatar
Lookin good man!
Thanks Brent!! I will start a new Thread that will sum everything up when she is all done! Thanks again
Old 05-11-2011, 01:51 PM   #31
drusmith's Avatar
It was night and day difference. I had sub frame connectors on it before. i took them off and replace with this kit. UNREAL feel and my top doesn't shake as much when going over bumps. Good stuff.
Old 05-11-2011, 01:53 PM   #32
1ijack's Avatar
Send a message via Yahoo to 1ijack
Looks sharp. I remember when you first got it and you have changed it to make it yours. Great mods and look forward to seeing the final result.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 05-11-2011, 02:04 PM   #33
nice, subframes like that should be on EVERY 94-04 vert period right from the factory...
Old 05-11-2011, 02:04 PM   #34
drusmith's Avatar
Thanks bro!!! I am excited to! Gonna be an *** kicker!
Old 05-11-2011, 02:09 PM   #35
drusmith's Avatar
AGREE 100%
3.8 V6 dyno Tune Results robb15033 Pre-2005 V6 Mustang 12 11-27-2010 08:01 PM
Dyno results gmantheman 2005-2010 Mustang GT 11 10-07-2008 12:23 PM
Test N' Tune Results Thomas91169 General Mustang Discussion 8 07-08-2006 08:35 PM
SCT Tune / Dyno #2 Results 2005RedGT 1996-2004 Mustang GT 9 02-21-2005 09:36 AM
99^ split port camming and tune dyno results... (NO PORTING!!!) RGR Pre-2005 V6 Mustang 6 04-09-2004 07:07 AM
07:38 AM
