lots of water and car is stalling at highway speeds - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 06-06-2011, 08:57 AM   #1
Pureoctane2001's Avatar
Well while driving down the highway in my 01 cobra in 5th gear red light comin up, throw car in neutral and motor cuts out check engine light and batter light both on. Turn the key it fires right up. Did that a few times this week. Then after we got home from cruising last night turned the car off and there is water streaming out from under the passenger side. The ac was on but there was a huge pool of water and it's streamed and went halfway across my garage floor about 5 inches wide. Any ideas?
Pureoctane2001 is offline   Reply With Quote
Old 06-06-2011, 09:41 AM   #2
wereKEV's Avatar
Re: lots of water and car is stalling at highway speeds
sounds like your heater core is leaking or the cabin filter is clogged.
wereKEV is offline   Reply With Quote
Old 06-06-2011, 01:30 PM   #3
I will ask my main mechanic about that later Would that cause the car to staul out tho?
Old 06-06-2011, 01:45 PM   #4
Stang.racr's Avatar
If it got to hot it will shut off or blow a head gasket
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 06-07-2011, 12:49 PM   #5
Ya. It wasn't running hot at all. Coolant full Turned the rpms up Went to a aluminum flywheel insert from factory so rpms were low and car died after neutral at high rpm. They dropped to low. Turned it up to 900-1000 not a prob dying since. I'm just trying to figure out the water now
Old 06-07-2011, 02:23 PM   #6
junoS197Bl08's Avatar
make sure that the drainage pipe for your ac isn't somehow stopped up, or maybe it was and then it opened back up when you got back parked.
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 06-07-2011, 02:30 PM   #7
Good idea. Will check that asap
Car Stalling after disconnecting battery nero 1979-1995 Mustang GT 7 01-17-2011 02:01 PM
Car Stalling megax29 Pre-2005 V6 Mustang 7 01-26-2007 09:46 AM
88 Coupe factory 5.0 5 speed car in KY CHEAP LOTS OF MODS fordguy23 Mustangs for Sale and Wanted 4 08-08-2006 04:22 PM
Flooded Highway = Hydroplane = Water Damage and New Front Bumper Cover Needed kaper232 The Bar 13 07-24-2004 02:50 PM
Pics of the car with fresh coat of water less car wash SpectorV Mustang Audio & Video 22 02-23-2004 08:12 PM
09:28 AM
