0-160 base run test before supercharger - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 06-09-2011, 07:29 PM   #1
Send a message via Skype™ to Texastboneking
this is my base test run before the supercharger so i can see the effects of the supercharger.. crappy tires and wheel spin. closed road of course.
Texastboneking is offline   Reply With Quote
Old 06-09-2011, 07:45 PM   #2
Re: 0-160 base run test before supercharger
WHat blower you going with?
Old 06-09-2011, 07:55 PM   #3
2004 factory svt blower
Old 06-09-2011, 08:43 PM   #4
Nice run!
For keeping it safe as possible.
Old 06-09-2011, 08:45 PM   #5
Thanks!
Old 06-09-2011, 09:49 PM   #6
Las0mbra's Avatar
Damn son! What happened between 110-120ish? Seemed kind of sloppy
Old 06-09-2011, 09:54 PM   #7
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Why not go to a drag strip if you want to see REAL before and after results?
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-09-2011, 10:51 PM   #8
-Will
because i could not hit 160 on a drag strip. unless it was the texas mile. and they dont open till October...
Old 06-09-2011, 10:52 PM   #9
that would be the shift into 5th. and i think my clutch slipped a little bit. i got a cheap clutch right now. will upgrade when i get the charger on it
Old 06-10-2011, 08:04 AM   #10
Titus Wadicus
svtlx's Avatar
wut gear u got? and thatsa 5spd not a 6spd right?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 06-10-2011, 08:36 AM   #11
5 speed t45. And 3.73
Old 06-10-2011, 09:12 AM   #12
Out of curiosity...why are you using 160 as your baseline? Wouldn't 1/4 times like was mentioned and a dyno be just as good while being a whole lot safer?
Old 06-10-2011, 09:16 AM   #13
drusmith's Avatar
Send a message via Yahoo to drusmith
Awesome run bro! You will see a big difference from the 90 to 160 range when you get the blower on! Sick power all the way thru!! I am excited to see your results.
drusmith is offline   Reply With Quote
Old 06-10-2011, 09:19 AM   #14
Well I'm going to do a 1/4 time too. I just wanted to see the difference in pick up speed at high speed.
Old 06-10-2011, 09:19 AM   #15
Thanks
Old 06-10-2011, 09:20 AM   #16
drusmith's Avatar
Love top speed runs! As long as they are safe, they rock!
Old 06-10-2011, 09:22 AM   #17
Things were flying by lol it was a rush
Old 06-10-2011, 10:37 AM   #18
wereKEV's Avatar
There is nothing like taking your car out and opening it up ,its just hard to find a place to do it.
wereKEV is offline   Reply With Quote
Old 06-10-2011, 05:20 PM   #19
If you can't hit 160 in the 1/4, you just haven't built enough car....
-Will
Waffles
Old 06-10-2011, 05:25 PM   #20
-Will
hey this car is a budget build car... bought it for 4800, motor in for 1500. supercharger free. you cant tell me that aint a good deal
Old 06-10-2011, 05:35 PM   #21
Watched your video...
Every B-headed 4V in existence needs gears......follow suit
-Will
Waffles
Old 06-10-2011, 05:37 PM   #22
its got 3.73 gears... is it not clear enough???
Old 06-10-2011, 05:39 PM   #23
Needs more gear
-Will
Waffles
Old 06-10-2011, 05:41 PM   #24
Needs more gear
-Will
even with the supercharger??? keep in mind this is a daily driver that hits the highway everyday. dont want my rpms way up the whole time. i was thinking 3.55s
Old 06-10-2011, 05:43 PM   #25
Don't think of the car like a foxbody, it turns significantly more RPMS....and it is built to do it.
-Will
Waffles
Old 06-10-2011, 05:47 PM   #26
-Will
i was thinking more of going from 14mpg down to 10 mpg. the car is already faster than most things in the town. im sure the supercharger will top it off well
Old 06-10-2011, 05:54 PM   #27
If you get 14 MPG you either need to fix something, get a tune, or learn to drive.....I've owned 2 96-98 Cobras that were (one currently is) more heavily modded than yours. Both averaged about 22ish highway, about 18-19 in town
-Will
Waffles
Old 06-10-2011, 06:02 PM   #28
epa estimates 15 city. so your doing good. and i drive a little hard. running factory tune 97 tune on 01 engine right now. throws a code for intake runner control but owell. but here in the hot and dry texas air. its hard to get good mileage... will get a tune when i get the charger. just dont want to pay to have it done twice
Old 06-10-2011, 09:30 PM   #29
Make sure and budget for headers if you don't have them.
-Will
Waffles
Old 06-11-2011, 02:00 PM   #30
-Will
My '96 will get 24+highway and around 18-20 city....but that's only if you drive easy...if you mess around at all my mpg's drop a ton...................
but I haven't had mine that fast and I don't think I will so I'll just pretend this is a viideo of mine!!
2008Shelby is offline   Reply With Quote
Old 06-11-2011, 02:49 PM   #31
Yeah, I have a feeling he drives like his age would lead one to expect
-Will
Waffles
Old 06-11-2011, 03:24 PM   #32
I've seen all ages drive hard in a muscle car.........I mean you really just can't resist it sometimes haha
Old 06-11-2011, 03:55 PM   #33
When you're just driving, you should drive.....when you're racing, you should race....if you race around all the time, you shouldn't get upset when you get 9 MPG or when stuff constantly breaks
-Will
Waffles
Old 06-11-2011, 09:41 PM   #34
-Will
You should put that as your signature.
Old 06-11-2011, 09:48 PM   #35
oh I agree completely...I drive easy most of the time but sometimes I like to have fun....I was just saying my MPG's suffer more in my cobra than in my '08....I've never gotten as bad as 9 though and I hope I stay far from it!!!! haha
Looking at a 03 Mustang Base, what should I look for? Tuscloud 1996-2004 Mustang GT 10 08-03-2010 02:14 PM
Problems With My 1995 Base Mustang MALITOU Pre-2005 V6 Mustang 4 04-08-2010 07:11 PM
0-160 in 1.2 seconds... lowflyn The Bar 19 03-06-2005 12:52 AM
Tornado went thru my base 97Stallion The Bar 13 09-07-2004 10:24 PM
a little help from everyone I need a broad base of knowledge please cuban3jumper Pre-2005 V6 Mustang 4 06-27-2004 10:07 PM
07:41 PM
