auburn locker?? - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 06-12-2011, 09:24 PM   #1
Black99Snake's Avatar
auburn locker??
so I'm in the process of rebuilding a built proof rear end in my cobra do to so slicks and a hard life. I've found everything I need from ford racing, but I'm thinking of putting in a auburn locking diff. I found a auburn locking diff for $100 from jegs. my question is there anything special I need to buy to go with it? im not to knowledgable with rear ends. I'm tryin to build something that will hold up to 1000rwhp that's my goal when I come back from deployment in 2013. I'm goin with 4.10s and cheapest route possible. so any input would help thanks guys.
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 06-12-2011, 09:56 PM   #2
Send a message via Skype™ to Texastboneking
Now this is clutch style right??? If so I like it. My buddy has it in his 57 chevy. He pops wheelies off the line and no problems yet. Seams pretty stout.
Texastboneking is offline   Reply With Quote
Old 06-12-2011, 10:00 PM   #3
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: auburn locker??
If you truly want to hold that much HP, your best bet is a spool or a detroit locker.
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-12-2011, 11:33 PM   #4
iwannagofast's Avatar
Re: auburn locker??
I have an auburn pro series and i love it, the only thing is that you have to change the fluid on it often otherwise it gets thick and doesnt lube the spider gears well and then the ***** will pop when you take corners at slow speeds
iwannagofast is offline   Reply With Quote
Old 06-13-2011, 12:22 AM   #5
it's a mini spool if that says anything. it's cheaper than goin with the ford racing LSD. but I'm tryin to figure out what would be the best choice LSD or the locker?
Old 06-13-2011, 06:50 AM   #6
Re: auburn locker??
A spool or mini spool will give you no slip whatsoever. They tie both axles together 100% of the time. They are not the best option for a regularly street driven car, and they are VERY hard on axles when taking turns....
It depends on what you want when talking about Limited Slip/Posi Track or Locker....if you're actually needing to support high HP, go Locker. If you're going to support 300-600 and you want great street manners, get a Ford 31 spline unit and pack an extra clutch or two in it.
-Will
Waffles
Well Auburn Brent The Bar 14 12-02-2008 09:04 PM
Gears and Locker coolstang Pre-2005 V6 Mustang 9 05-14-2007 09:49 AM
So how bout Auburn? Zim The Bar 84 11-14-2006 06:12 AM
FMS or Auburn 01mineralgrey6 Pre-2005 V6 Mustang 12 02-17-2005 02:06 PM
detroit locker vs. limited slip oaktonarcher Pre-2005 V6 Mustang 15 07-10-2004 01:27 PM
04:39 AM
