Steeda Tri ax short shifter install..... - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 07-22-2011, 07:10 PM   #1
rinfield2004's Avatar
Gonna install a steeda tri ax short throw in my 01 cobra in the morning when I get off work. Any heads up on how the shifter assy disassembles? Any pointers, tips, and advance for smooth install would be kick ***. Look forward to hearing from you guys.
rinfield2004 is offline   Reply With Quote
Old 07-23-2011, 09:13 AM   #2
Black99Snake's Avatar
Pretty simple and easy. Just remove the shift knob then the shift boot pulls up and that is held down by two clips don't break them they hold the boot down. Then there are four 8mm bolts that hold down a sound deafening pad pull that up then there are four 13mm bolts that hold the actual shifter down then that just pulls up and you repeat all those steps in reverse to put it back together. Should take about 15 minutes
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 07-23-2011, 09:22 AM   #3
Jamesgt08's Avatar
Yepp pretty simple. You will love the steeda shifter i have it on my car and i love it.
Jamesgt08 is offline   Reply With Quote
Old 07-25-2011, 07:48 PM   #4
Do you have to adjust the shifter?
jonboyc6 is offline   Reply With Quote
Old 07-26-2011, 09:14 AM   #5
Re: Steeda Tri ax short shifter install.....
its actually rather easy, if you would take pics of the process I will create an article for the how to and put your name on it for submission of images.
take the knob off
slowly pull the shifter boot plastic thing up and off (4 clips hold it on and those like to pop off... makes for rattles on reinstall). Check that you have all metal clips on the plastic tabs, if you dont look for it as it may have fallen off
Next you will see 4 bolts at each corner of the metal ring/rubber surround. Those are a pita to get off without a swivel socket. Take those off and then slowly slide it forward and up and wiggle it out after taking the handle off. You may want to take the handle off first to get more access.
Then you see 4 bolts holding the shifter on. Remove those and then you can put the handle back on the shifter and use it as leverage to wiggle the shifter side to side and front to back to pop it off. Use a razor blade to clean off the RTV gasket, dont let any fall into the trans tunnel, if you do clean it out fully.
Now is a GREAT time to change trans fluid as you can pour it in the trans opening where the shifter was FYI
use new RTV or a shifter gasket (shifter gaskets are GREAT and help noise so I would recommend that as the steeda shifter is not as well made as MGW etc and makes more noise.
with RTV on transmission (around the inside of the bolt holes as well) or gasket reinstall carfully making sure not to cross thread the shifter bolts, snug down, I would not install the shifter stop bolts at all but thats your choice.
Reverse process and your done.
Old 09-01-2011, 07:08 PM   #6
nickdandria's Avatar
Do you have to go from under the vehicle? I've read some installation manuals and some say you need the car on a lift or on jackstands.
2005 s281 Saleen, 5 speed.
Soon to come:
Short throw kit, CAI.
nickdandria is offline   Reply With Quote
Old 09-01-2011, 07:47 PM   #7
Jamesgt08's Avatar
To change out your shifter? Noo you can do it while the car is on the ground.
You just pop of the plastic piece unsrew ur shifter handle take off the boot and there are four bolts that hold down ur shifter. Easyyy
Old 09-01-2011, 09:38 PM   #8
What about if it's the saleen adapter one? A buddy of mine got me one and I've yet to install it cause Im unsure of what's involved.
Soon to come:
Old 09-01-2011, 09:53 PM   #9
Jamesgt08's Avatar
Take a picture of tje shifter and post em.
Old 09-01-2011, 09:55 PM   #10
Hope thats a good pic
Soon to come:
Old 09-02-2011, 12:40 AM   #11
93slowstang's Avatar
Here is the directions from AM which is what Spector stated.
http://www.americanmuscle.com/steeda...r-install.html
---------- Post added at 01:40 AM ---------- Previous post was at 01:28 AM ----------
Yours is different than the 79-04 stangs. Here's the directions for yours.
http://www.americanmuscle.com/steeda...t-install.html
WTB/ short throw shifter 93stang306 Mustang Parts for Sale and Wanted 0 06-25-2011 08:10 PM
10:36 AM
