Need some feedback pls - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 08-30-2011, 01:51 AM   #1
Elcobrachingom's Avatar
Does the 03/04 cobra when u lowered does the driveline need to be adjust it to the new height ..or does the driveline comes down together because the the IRS any help would b aprexiated thamks
Elcobrachingom is offline   Reply With Quote
Old 08-30-2011, 08:39 AM   #2
Black99Snake's Avatar
Most likely you'll have to have the caster and camber adjusted and if you go real low you'll prolly need caster camber kit for the front the rear should adjust so what the same but easiest thing to do is take it to a alignment shop and they can square it all away correctly
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 08-30-2011, 09:43 AM   #3
Oh ok so theres nothing else to do to the driveline after dropped just the alignment for sure right...i really apreciate for taking ur time thank u
Old 09-06-2011, 09:20 AM   #4
drusmith's Avatar
Send a message via Yahoo to drusmith
Re: Need some feedback pls
Yes, get the Caster Camber plates! I have them! It makes it 100% easier to do an alignment on our cars!
drusmith is offline   Reply With Quote
Old 09-06-2011, 10:18 AM   #5
the front AND rear on an IRS vehicle have to be aligned. You should not need C/C plates for the rear but you will need them for the front if you have any sort of a drop (more than .75 inches).
Old 09-06-2011, 10:20 AM   #6
If you need C/C plates (probably will same basic install is needed for them as springs (or most of it) so you may as well invest in a set now. I HIGHLY recommend Maximum Motorsports 4 bolt C/C plates (best on the market)
Along with them since the 04/04 cobra have different shocks up front than normal the dust boots wont work with MM's C/C plates. They also sell the correct dust boots and they are cheap so be sure to order a set when you order your C/C plates. You can call maximum motorsports for info on them.
You can also look into new endlinks~ as when you lower the car you push the sway bar up a bit where it mounts to the A-Arms... not needed just FYI.
Old 09-07-2011, 01:45 AM   #7
Reallly ...are they easy to install?
---------- Post added at 02:45 AM ---------- Previous post was at 02:41 AM ----------
Yes i did the alingment on all four wheels...so what its the purpose of the caster camber plates(im sorry im a rockie in the car mechanic do it yourself stuufff) cuz yes my car got dropped ,,i think 1" front and 1 1/2 back (eighback pro kit springs).
Old 09-07-2011, 07:04 AM   #8
drusmith's Avatar
Very easy to install!
HELP! need feedback on the 05 4.6L the good,bad,and ugly bryanbrock 2005-2010 Mustang GT 8 08-15-2011 06:49 AM
10:03 PM
