Kenne Bell problems - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 09-19-2011, 08:32 AM   #1
Kenne Bell problems
I have an 04 cobra with a Kenne bell and boost a pump, has anyone had a problem with the car cutting out on low rpm part throttle acceleration?
04kbcobra is offline   Reply With Quote
Old 09-19-2011, 08:47 AM   #2
drusmith's Avatar
Send a message via Yahoo to drusmith
Re: Kenne Bell problems
Can you describe your issue a bit more? It kinda sounds like PPRV issue that every terminator has. What does the car do? Does it hesitate as you try to accelerate right after shifting?
drusmith is offline   Reply With Quote
Old 09-19-2011, 11:20 AM   #3
It doesn't do it right after shifting. Its mostly when it's low rpm and i'm trying to pass someone, almost like it's getting too much boost. And it started right after I put the Kenne bell on it. It was fine with the original eaton. Let me know If this helps or not? I've been trying to figure it off and on for a little while. And I'm wondering if I just need to get a customized tune for it or not
Old 09-19-2011, 11:53 AM   #4
drusmith's Avatar
Yup that is the dreaded PPRV air bubble issue. I just did mine by myself 2 months ago. You have to drop your tank and replace Parallel Pressure Relief valve with a "Y" connector and new tubing. See pictures and link I have provided! Easy to do. i did it in about 2.5 hours but I had to drop the tank twice because I forgot to tighten one fuel line and it popped off. You can only view this video from computer not mobile phone
Name:	PPRV DELETE.jpg
ID:	31954   Click image for larger version
Old 09-19-2011, 11:55 AM   #5
drusmith's Avatar
.................. and this is where you can purchase said kit. Its 100% worth it bro. Oh and what size KB did you go with?
Lethal Performance PPRV Delete Kit with 30R10 Submersible Line [LP-PPRVDELETE] : Lethal Performance, Performance parts for Ford Mustangs
Old 09-19-2011, 12:27 PM   #6
Definitely sounds like the PPRV issue to me as well.
Old 09-19-2011, 06:15 PM   #7
I went with the 2.6 " big bore" with a " big oval" throttle body. Thanks for all your help, will definitely try this and see if it works
Old 09-20-2011, 08:38 AM   #8
drusmith's Avatar
Nice 2,6L!!! I have the Big Oval as well on my 2.2L. What have you put down as far as HP? I made 590rwhp.
Old 09-20-2011, 09:04 AM   #9
I haven't dyno'd it yet, trying to fix this problem first.
Old 09-20-2011, 12:25 PM   #10
drusmith's Avatar
Good plan! Let us know how you come out! And let me know if you need any help with the PPRV delete. Also post some pictures of your ride when you get a chance!
Old 11-07-2011, 09:04 AM   #11
Yes I just changed for a friend of my he got the same problem, you can got the upgrade kid and u gone to see the difference, I am not a kenne bel person, so I hope Thad is u only problem, O a big thing Check the fuel regulator, on top of the fuel rail those do the same problem u got now 2
2003CobraSvt is offline   Reply With Quote
04 cobra shifting problems NickGeezy General Mustang Discussion 7 09-21-2011 11:41 AM
cooling problems dreamstang 1979-1995 Mustang GT 62 09-13-2011 05:19 AM
Kenne bell question!! Need help Ahmed ali khan 1996-2004 Mustang GT 26 08-11-2011 05:24 PM
Different Starting Problems milkrun49 2011-2014 Mustang GT 3 07-15-2011 03:19 PM
Carburetor problems Tyoung68 Classic Mustangs 2 07-12-2011 12:43 PM
12:03 AM
