speedometer - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 12-19-2011, 11:02 PM   #1
Butch's Avatar
Region: New Mexico
speedometer
My speed o reader is off and kicks in at certain times, which is usually about 30. It'll stay reading as long as I dont drop below 30ish. Plus the faster I go the more its off by. Dodge caliber marked 70mph mine 90. Caliber marked 100 mine 130mph. What could it be?
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 12-20-2011, 03:07 AM   #2
Re: speedometer
And what's a speedo reader?
SonicBoom239 is offline   Reply With Quote
Old 12-20-2011, 08:47 AM   #3
Butch's Avatar
Region: New Mexico
Speedometer
-----NEHP---
{Never Enough HP}
Old 12-20-2011, 08:51 AM   #4
Re: speedometer
do you have rear end gears? have you had the needles off? they can stick if you dont put them on right after taking them off etc
Old 12-20-2011, 09:03 AM   #5
Butch's Avatar
Region: New Mexico
That's the thing I bought the car as is but I do think it has gears.
-----NEHP---
{Never Enough HP}
Old 12-20-2011, 09:06 AM   #6
Gster's Avatar
When I put 4.10 in my 2000 GT I had to change the speedo gear in the tranny.
Gster is offline   Reply With Quote
Old 12-20-2011, 09:08 AM   #7
Butch's Avatar
Region: New Mexico
Ah then that's the thing I should check next
-----NEHP---
{Never Enough HP}
Old 12-20-2011, 09:10 AM   #8
Gster's Avatar
If that is what it is, which I'm pretty sure it is, get 2 or 3 of them because there plastic and the teeth wear out easy. There probably about 5 bucks each.
Old 12-20-2011, 09:24 AM   #9
Butch's Avatar
Region: New Mexico
Cheap plastic parts I dont know why they make em. Rather spend a few more faces for an aluminum one. Then ill go ahead and put my money onto that one.
-----NEHP---
{Never Enough HP}
Old 12-20-2011, 09:33 PM   #10
vinnygt's Avatar
I was recommended the speedcal when I came across this problem
vinnygt is offline   Reply With Quote
Old 12-20-2011, 10:07 PM   #11
Butch's Avatar
Region: New Mexico
What's the speedcal?
-----NEHP---
{Never Enough HP}
Old 12-21-2011, 01:34 AM   #12
Re: speedometer
time to find out....
jack up the car in the rear and get under it...take a marker and make a dash on the driveshaft...now spin the rear tire one full rotation...as you spin the tire by hand count how many times the mark reaches the point it started...you'll know pretty fast what gears you have back there..
3 1/4 turns = 3.27s
3 1/2 turns = 3.55s
3 3/4 turns = 3.73s
4ish turns = 4.10s
so on and so forth...
Old 12-21-2011, 07:51 AM   #13
Re: speedometer
you can tune the speedo to fix it, you cant put a speedo gear in 99+ mustangs (dont have one)
Old 12-21-2011, 07:57 AM   #14
vinnygt's Avatar
A little device that hooks up to the tranny I believe and it converts the speed readings for when u change gears or wheel sizes but u have to know what gears u have in your car in order to make it work properly cuz when u instal it u have to put in your old gears size and your new gear Size so that the device knows what it needs to convert
Old 12-21-2011, 09:31 AM   #15
Gster's Avatar
My mistake it was my 95 GT put 4.10s in that needed a speedo gear. My 2000 I never touched the gears for that reason. They all run together after 4 of them.
Old 12-21-2011, 10:09 AM   #16
Butch's Avatar
Region: New Mexico
3 1/4 turns = 3.27s
3 1/2 turns = 3.55s
3 3/4 turns = 3.73s
4ish turns = 4.10s
Saweet thanks for the knowledge
---------- Post added at 09:59 AM ---------- Previous post was at 09:58 AM ----------
Alright koo ima check that out. Hopefully today or here soon
---------- Post added at 10:09 AM ---------- Previous post was at 09:59 AM ----------
Ah ok well that's nothing I should over look any how.
-----NEHP---
{Never Enough HP}
Old 12-27-2011, 04:05 AM   #17
Aussie Stang's Avatar
Region: Australia
Never heard of a speedcal. I have a Diablosport predator, and although I have not changed the dif gears, the predator can re-program the cars computer to show the correct speed on the odo after such alterations.
Aussie Stang is offline   Reply With Quote
Old 12-27-2011, 03:22 PM   #18
Butch's Avatar
Region: New Mexico
Where can I find a predator and what is it?
-----NEHP---
{Never Enough HP}
Old 12-27-2011, 07:05 PM   #19
Region: Australia
Google Diablosport. I think it is www.Diablosport.com and is sold by a number of retailers. It is a handheld tool that plugs into the vehicles ecu (under dash).
Old 12-27-2011, 07:10 PM   #20
Butch's Avatar
Region: New Mexico
Koo. Thanks
-----NEHP---
{Never Enough HP}
Need help with speedometer Klinton 1979-1995 Mustang GT 11 12-09-2011 07:34 AM
Speedometer wvudodrill General Mustang Discussion 0 10-15-2011 03:45 PM
speedometer problems Qwik Four Six 1979-1995 Mustang GT 15 10-07-2011 09:28 PM
Speedometer help! 89 Foxloco 1979-1995 Mustang GT 13 08-07-2011 05:23 PM
Free saleen speedometer Qwik Four Six 1979-1995 Mustang GT 12 06-25-2011 05:05 PM
04:48 AM
