clutch. - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 01-10-2012, 11:42 AM   #1
Butch's Avatar
Region: New Mexico
clutch.
My clutch bearing, so im told it is, will squeak after a bit of use. Ill stop get off and do what I gotta do and its gone till I use it a while. Any possible solutions?
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 01-10-2012, 01:35 PM   #2
Black99Snake's Avatar
You mean your throwout bearing. It's on your input shaft in the bellhousing you have to drop the driveshaft and unbolt the trans from the motor and pull the trans back away from the clutch to get the throwout bearing off and new one in. Now if its the pilot bearing you have to do the same but also remove the clutch and flywheel from the back of the motor to get that one. You will need a pilot bearing puller or pry it out. Good luck
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 01-10-2012, 02:48 PM   #3
Re: clutch.
throwout, they sqeek eventually. If the clutch is new either they didnt replace it or they didnt do it right.
You can try to take up the slack in your clutch a tiny bit (manually adjust PM me if you need to know how)
If u have air in the break fluid can that make ur clutch pedal feel stiff? bluestorm52 2005-2010 Mustang GT 7 12-10-2011 04:49 PM
New guy with a clutch question Cajunick 1996-2004 Mustang GT 7 11-15-2011 11:32 AM
Clutch eouellette18 2005-2010 Mustang GT 9 09-08-2011 03:51 PM
Clutch just went 04machazblue 1996-2004 Mustang GT 9 08-24-2011 05:41 AM
Clutch? :( nickysixx 1996-2004 Mustang GT 5 07-08-2011 04:13 PM
04:23 AM
