Found my problem - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 01-14-2012, 10:31 AM   #1
vinnygt's Avatar
Found my problem
Well I noticed I had been leaving a lot of oil in my girlfriends drive way and if u can remember my check engine light had been on and my car would shut off when I would floor it and put it in neutral. Well last night I decided to check and follow where the oil was coming from and it ended up coming from my sc. The problem was that the rubber hose thing that connects to the sc keeps slipping off. I tried to clam it back on and as soon as the clamp gets tight the rubber slips off the sc. I am very irritated. Lol. I can't get the damn thing to stay. Any suggestions?
vinnygt is offline   Reply With Quote
Old 01-14-2012, 12:06 PM   #2
U may have to replace the hose.is your clamp towards the end of where it. Connects?or is the hose note going all the way on when clamping it?
Old 01-14-2012, 10:40 PM   #3
vinnygt's Avatar
The clamp tightens up good but the hose fits on the sc pretty loose so even when I tighten it, the hose eventually slips off. I'm gonna call vortech and see if they can send me a correct size hose or a cupling to make that hose fit or something. I cleaned up all the oil with brake cleaner and left it all nice and dry. With a LOT of patience I was able to get the hose to stay. I know it will slip off as soon as oil hits it but for now it should be good. But my check engine light still doesn't go away. Do I have to take that off with the scanner?
---------- Post added at 12:40 AM ---------- Previous post was at 12:37 AM ----------
The space on the sc for the clamp to grab on to is very limited. About an inch. Only a bit bigger than the actual clamp. So if I'm off by a little the whole thing just comes off while I'm tightening. I will try to have some pictures up tomorrow morning
Old 01-16-2012, 10:45 PM   #4
vinnygt's Avatar
There's my problem. Hope you guys can see. It just won't stay should I call vortech and see if they can get me a tighter hose?
ID:	38347   Click image for larger version
ID:	38351   Click image for larger version
Fox found Jpstang 1979-1995 Mustang GT 50 10-18-2011 11:49 AM
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 8 08-24-2011 09:51 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
Shift knob problem with steeda tri-ax apex32 2011-2014 Mustang GT 5 06-29-2011 01:04 PM
07:56 PM
