Speedo recalibrate - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 02-21-2012, 10:15 AM   #1
McNassty's Avatar
Speedo recalibrate
Does anyone know the name of the part to recalibrate my speedometer? I just switched to 3.73's and I wanna know my true speed. Isn't it just a small plastic gear?
McNassty is offline   Reply With Quote
Old 02-21-2012, 11:55 AM   #2
Wcelitegoalie19's Avatar
What year? You can most likely use the handheld tuner
Wcelitegoalie19 is offline   Reply With Quote
Old 02-21-2012, 12:24 PM   #3
Re: Speedo recalibrate
pre 99 you can install a speedo gear, it wont be 100% but it will get it closer. You can modify it in the tune on 99+
Old 02-21-2012, 02:11 PM   #4
McNassty's Avatar
She's a1995 SVT, I thought it was a speedo gear but every search online I do just gives me pics and specs. I can't find anyplace to order them, I tried Summit, American Muscle And AutoZone. Nothing and if they do have them (American Muscle) than its just for an automatic
Old 02-23-2012, 03:18 PM   #5
32vNomad's Avatar
You can still get speedo gears from Ford. Also check latemodel resto what one is it you need?
32vNomad is offline   Reply With Quote
Old 02-23-2012, 05:37 PM   #6
McNassty's Avatar
Found it, just had to get out of class so I could actually talk with the Summit operator. The only problem was I only ordered the speedo gear and now I have to wait another two days until I will be able to know how fast I'm actually going. Can I install the speedo gear now and install the gear ring when I get it? And if I can is it going to tear the speedo gear up?
Old 02-23-2012, 06:07 PM   #7
32vNomad's Avatar
You only need to change the gear. The gear on the tail shaft is a certain color. There are combinations of ring and gear to go together for certain gears. What rear end gears do you have installed or did u change tire size
Old 02-24-2012, 05:29 PM   #8
McNassty's Avatar
Really, cause that is awesome. It means I wasted twenty bucks but screw it if I don't have to pull the case apart. I threw in 3.73's, I sent my chip to BAMA yesterday. Can't wait to plug that in! I just spent eighteen hundred bucks on upgrade parts, that'll pull everything together
Old 02-24-2012, 06:16 PM   #9
32vNomad's Avatar
http://www.fordracingparts.com/download/charts/129.pdf
Follow that link it will help you out. I'm suprised that this is not on the stickys because its very good and an important doc.
Speedo? Burkeys96GT 1996-2004 Mustang GT 1 01-22-2012 04:42 PM
87 5.0 speedo upgrade: help? Buckallred 1979-1995 Mustang GT 11 01-20-2012 01:06 AM
fast speedo brian94gt 1979-1995 Mustang GT 4 10-25-2011 09:13 PM
speedo and gauges problems kirpy 2005-2010 V6 Mustang 0 10-20-2011 06:36 PM
speedo correction rix71gt 1996-2004 Mustang GT 10 10-07-2011 12:30 PM
06:31 PM
