Drone noise - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 04-03-2012, 09:10 AM   #1
Rosco's Avatar
Drone noise
When I hit 40mph a slight drone noise starts and lasts to 45mph, after that it's gone. The noise sounds like a ghost going oooooouuuuu. The gear I'm in doesn't seem to matter if trying to avoid the sound. It may be a bearing( hoping not ). Any thoughts? I don't know if these are related but when going from first to second, after the engine is warm, the shift can be really tough sometimes. Seems to always be when shifting below 3200rpms because above that the shift slides in easy. Are my synchro's bad?
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 04-03-2012, 09:17 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Drone noise
wut exhaust are u running?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-03-2012, 09:20 AM   #3
doug5.0's Avatar
That happened to me... Turns out I just needed a louder stereo! LOL!
CURRENT: 2016 GTPP, Vortech, Ford/Borla cat back, 1" drop on Vogtland, 1" Hubcentric spacers, APR Front Splitter, RTR Upper Grille.
SOLD: 2011 5.0, Auto, C&L CAI, Dyno Tuned, 3.73s, Boss 302 Intake, Magnaflow Competition axlebacks, Stallion Suspension LCAs, Whiteline Sway Bars.
doug5.0 is offline   Reply With Quote
Old 04-03-2012, 10:33 AM   #4
Echo that. My Mac pro chamber & flows back generate a nice drone inside but I personally love it. F the radio IMO
---------- Post added at 12:33 PM ---------- Previous post was at 12:31 PM ----------
I'm not sure about that honestly accept its the exhaust set up your running maybe. The tranny is weird at times when it's cold ... But it goes in gear no prob but has a ratching sound that goes away.
SNK3BTE04 is offline   Reply With Quote
Old 04-03-2012, 03:58 PM   #5
Rosco's Avatar
The exhaust is all stock so it's not an aftermarket possibility. The drone noise happens whether or not the car has warmed up and seems to only occur around 40-45 mph. About the shifter I think it's okay, it seems to be doin fine for some reason.
Old 04-04-2012, 11:47 AM   #6
Prob because most speed limits you cruise at is 40-45 and the RPMs your running are causing it to drone. Is the car a auto or man?
Old 04-04-2012, 03:56 PM   #7
Rosco's Avatar
The car is manuel. I'll drive it at 40-45 in 2nd but I think it will still drone. I'm pretty sure it's the mph itself and not the gear and rpm in relation to 40-45 mph.
Heater Noise? Montie 2005-2010 V6 Mustang 22 04-09-2012 05:59 PM
loud squeal noise when certain rpms? Cobra209 SVT Mustang 13 04-06-2012 05:42 AM
12' Convertible makes chirping noise over bumps by conv latch?? Yellow50 2011-2014 Mustang GT 2 04-04-2012 12:15 PM
Amp back feed noise through speakers SNK3BTE04 Mustang Audio & Video 16 03-28-2012 07:49 AM
Annoying tickin noise Crutch0694 Pre-2005 V6 Mustang 4 03-26-2012 10:52 PM
12:32 PM
