coolant cross-over tube - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 07-20-2012, 12:39 AM   #1
Butch's Avatar
Region: New Mexico
Yeah seems to be I gotta replace it =\ just looking for some advice and is there anything I should know or do before digging into it?
Do I gotta drain my coolant?
Or can I salvage it?
I stripped this part
About this far from ground up
Or would it be better to use this
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 07-20-2012, 12:45 AM   #2
Butch's Avatar
Region: New Mexico
Or even this kit
-----NEHP---
{Never Enough HP}
Old 07-24-2012, 06:38 PM   #3
lBRAlD's Avatar
If you know the thread size you should be able to re tap it with no problems. Just use some good thread sealant when you plug it back up. I wouldn't think you would need a heli coil kit.
lBRAlD is offline   Reply With Quote
Old 07-24-2012, 10:52 PM   #4
Butch's Avatar
Region: New Mexico
What's the difference between tapping it to using a heli coil kit?
-----NEHP---
{Never Enough HP}
Old 07-24-2012, 11:40 PM   #5
lBRAlD's Avatar
When you tap it you just retrace original threads(pretty much clean them up). Heli coil you drill, tap then insert coil. (pretty much when threads are destroyed) if my threads were that bad I'd tap one size larger and get one size up plug. I think you would be fine just tapping. Make sure to undo hose directly beneath (shavings will fall) and when you tap make sure to hold firm pressure and keep tap straight up(slowly is better).. Hope this helpful.
Old 07-24-2012, 11:43 PM   #6
Butch's Avatar
Region: New Mexico
Ah ok, , koo, ,, yep sure did, thanks bro
-----NEHP---
{Never Enough HP}
01:13 PM
