IRS mods? - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 07-26-2012, 11:08 PM   #1
IRS mods?
I'm looking to upgrade my suspension to eliminate some wheel hop and put more power to the road than side to side and hopping around. Anybody have some good recommendations? I was thinking diff brace and polyurethane diff and subframe bushings to start off with but not sure where to go after that.
Cobraman8801 is offline   Reply With Quote
Old 07-27-2012, 04:57 AM   #2
bmabbott's Avatar
Re: IRS mods?
That's a great start! doing the same thing here soon. I just want to eliminate a little bit of the wheel hop at the strip, but I'm not removing the IRS since it handles like a dream in the turns.
Where are you getting the differential brace from?
*01 Cobra, 4.6L, P&P heads, Stage 3 comp cams, MAC LT headers, O/R Hpipe, Bassani catback exhaust, Too many bolt-ons to list..., 4.30 gears. (364 rwhp/ 330 rwtq)
*01 Roush Stage 2, 4.6L, 5 spd, BBK Bolt-ons (Wife's)
*71 Chevelle, 350, 4 spd, H/C/I, (~400 hp)
*72 C10, 350, Auto, (my Daily Driver)
bmabbott is offline   Reply With Quote
Old 07-27-2012, 06:42 AM   #3
Full tilt boogie bushings kit and billetflow brace with new springs.
Best mod is the sra mod, love mine
Old 07-27-2012, 07:42 AM   #4
Re: IRS mods?
Full tilt boogie is probably the best way to go, sure SRA solves many issues but you sacrifice a few things to get there. Overall both ways have good/bad its just a matter of what you want out of the car. Stock the IRS has MANY shortfalls (especially 99-01 versions) but.... with some money invested you can turn it around.
I installed an IRS brace (a must) as well as stiffer springs along with wider tires and I really dont have hop, but this is on the street not sure on the track (probably would hop on the track)
Old 07-27-2012, 08:28 AM   #5
I had bushings, brace and forward torque brace. Broke a halfshaft launching at track and another shifting into second on the street.
Haven't found a single downside to my sra yet
Old 07-27-2012, 06:41 PM   #6
Butch's Avatar
Region: New Mexico
Heard but I couldn't find it, that the polyurethane bushings are no bueno, dont quote me on this but to my memory that's what I've heard. Keep asking though
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 07-27-2012, 08:41 PM   #7
Re: IRS mods?
If you're doing bushings delrin is the way to go. Full tilt boogie also incorporates grease fittings into the factory unit
Old 08-14-2012, 09:23 AM   #8
drusmith's Avatar
Send a message via Yahoo to drusmith
Re: IRS mods?
Do yourself a favor. Buy the FT 5000 Kit and be done! I installed this with the grease fittings and I never had wheel hoop again. top 3 mod I ever did to my Cobra! Full tilt Boogie FTW!!!
Complete IRS Bushing Kit Includes: Aluminum Front diff supports with Aluminum shimming washers to set pinion angle, Delrin Rear Diff support, UHMW IRS Subframe support set, Delrin Upper control arm bushings and Hardcoated inner sleeves, Delrin Lower control arm bushings and Hardcoated inner sleeves with shimming washers, Combination UCA and LCA bushing grease fitting kit. One pair of Grade 8, 9/16" bolts with nylock nuts and flat washers for the front subframe mounts.
FT 5000 $645.00
This kit includes: FT 1000, FT 1100, FT 1200, FT 1300, FT 1500, FT 1600 and FT 1700 (Save $20)
FTBR Order Page
drusmith is offline   Reply With Quote
Old 08-16-2012, 11:46 PM   #9
Brodyd's Avatar
Is the IRS that big of a pain?
Brodyd is offline   Reply With Quote
Old 08-17-2012, 05:52 AM   #10
drusmith's Avatar
Depends on how much whp ur at and what you plan to do with your car.
Old 08-17-2012, 08:28 AM   #11
If you like the drag strip then yes. If you just want a fun street setup it's perfect.
I quite enjoy being able to dump my clutch at 4200 and not worry about grenading another halfshaft
Old 08-17-2012, 08:43 AM   #12
drusmith's Avatar
Re: IRS mods?
exactly!! ^
Old 08-17-2012, 08:51 AM   #13
Brodyd's Avatar
Re: IRS mods?
my cobra is an everyday car do you think keep the IRS as is is the best choice?
Old 08-17-2012, 09:19 AM   #14
drusmith's Avatar
Re: IRS mods?
OMG yes, if you just everyday driving it the comfort of the IRS is way better than solid axle option. If you want to get more aggressive with HP than look into one of the Full Tilt Boogie kits. Night a day difference when it comes to wheel hoop. And no more blown half shafts.
Old 08-17-2012, 03:15 PM   #15
Brodyd's Avatar
Re: IRS mods?
okay that's great for me then! but just for knowledge reasons isn't a IRS bad for drag racing?
Old 08-17-2012, 06:55 PM   #16
If you plan on running street tires or drag radials, yes. With a bias ply tire and some knowledge it's not all that bad
09:36 PM
