brakes - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 08-01-2012, 12:17 PM   #1
Butch's Avatar
Region: New Mexico
brakes
Gotta change a few studs on my driver rear, wondering how to take off my caliper. And what else I gotta do to take off the studs
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 08-01-2012, 01:37 PM   #2
1slosix's Avatar
Re: brakes
the caliper is held on with two bolts...super simple to remove...to take out the old studs a hammer is gonna be your friend after you take off the rotor (which'll pop right off)...i had to replace all 5 of my rear studs on my old GT thanks to a bad wheel install from a shop. the reinstall is easy as well..get yourself a lug nut that you don't mind destroying and a nut larger then the stud so that it's like a spacer (about 1" is tall is what i use).
now put a few drops of oil on the teeth of the new stud and slide them through the back of the hub...on the front of the hub put your spacer on the stud (the large nut)...then thread on the lug nut..now use an impact to pull the stud through
it's a quick job once you get the feel for it after the first stud
---------- Post added at 02:37 PM ---------- Previous post was at 02:37 PM ----------
here maybe this'll help
Old 08-01-2012, 03:37 PM   #3
Butch's Avatar
Region: New Mexico
Sweetness, thanks bro its cake. Guessing I should get the tool to open up the caliper?
-----NEHP---
{Never Enough HP}
Old 08-01-2012, 11:11 PM   #4
Butch's Avatar
Region: New Mexico
What's the difference between drilled and slotted rotors?
-----NEHP---
{Never Enough HP}
08:51 AM
