Clutch adjuster, clutch, or tranny - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 09-04-2012, 12:27 PM   #1
Elcobrachingom's Avatar
Hows it going guys..here with a small(big) problem with my cobra..my car wont go into any gear at all when car is ON..its like if my gears are locked or something..when its OFF it goes through every gear..when applying presure to clutch feels less presure than regular..the tranny its about ayear old bout 10000 since new and the clutch about 2 years ago installed..any subjestions well apreciated
Elcobrachingom is offline   Reply With Quote
Old 09-04-2012, 01:45 PM   #2
Cobrarunnin9s's Avatar
Re: Clutch adjuster, clutch, or tranny
I'd start with the Cable adjustment first, put your foot under the pedal and pull it up towards the dashboard and you should hear a click. If that's not it, go underneath and start checking the fork and linkages and inspect the clutch if you can as well.
Cobrarunnin9s is offline   Reply With Quote
Old 09-05-2012, 01:52 PM   #3
Thanks for advise ( cobrarunning9s) i havent had time to check it out till today maybe..i miss driving my car..
Old 09-05-2012, 07:32 PM   #4
no problem man, if the adjuster and linkage check out its time to check the clutch disc/pressure plate and flywheel for warpage or a broken finger.
08:41 AM
