Mk. VIII Engine into a Fox? - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 10-18-2012, 08:51 AM   #1
LaseRedXD's Avatar
Hey, guys.
I am thinking about dropping a Mk. VIII engine into my foxbody, it has nearly the same dimensions as a Cobra engine, right?
Do you know if I can use a mini brake booster with that setup, or will I have to convert to hydro brakes/manual brakes.
Opinions, please! =)
LaseRedXD is offline   Reply With Quote
Old 10-24-2012, 06:49 AM   #2
32vNomad's Avatar
I believe you will need to switch braking systems. Along with k member. But the cobra motors are Mark Motors and are the same in dimension
32vNomad is offline   Reply With Quote
Old 10-25-2012, 06:20 AM   #3
LaseRedXD's Avatar
Good deal! I was thinking no one was gonna answer me, lol.
Do you think it'd be easier to drop in my 98 v6? I have two mustangs and this engine sitting around...
Old 10-25-2012, 06:50 AM   #4
32vNomad's Avatar
Much easier with a sn95. There are some on here that have made that swap. There is a sticky for a Mark swap on this site under 96-04 section. It is for a New Edge but it is very similar. I myself have a Mark engine.
Old 10-25-2012, 07:42 AM   #5
LaseRedXD's Avatar
Okay, so the mark engine is basically a cobra engine minus the intake and little cam differences? Do you recommend the engine? Like is it reliable, any issues? Thank you so much, man.
Old 10-25-2012, 09:21 AM   #6
32vNomad's Avatar
Search my posts for 97 gt 32v swap. We have a lot of info overthere concerning the Mark engine as well as video. The Mark engine was first to appear in 93. The cobra came from the mark. A lot of guys will run the next gen cobra or mach setup on the teskid block. The engine is solid but depending on hp goals internals maybe changed. I myself built mine with forged internals but it isn't necessary if staying NA or juice. Or even 8-10lbs of boost even. The Mark has the same cam profile as the Mach. I do recommend the engine. As you can update it when you decide on goals.
06:12 AM
