system to lean bank 2 - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 01-27-2013, 07:16 AM   #1
kingc cobra 97's Avatar
Hello.. I have a 97 cobra. Motor is stock. Have o/r x pipe with no cats. I have a check engine light on, code is p1074 bank 2 system to lean. I have replaced mas airflow sensor, coolant temp sensor, intake gaskets. And im still getting the same code. (note).. if i dont let the car warm up for a few minutes first thing in the morning it will fall on its face before i get half a block down the road and wants to die.. Once it warms up it runs fine for the rest of the day.. Thank you
kingc cobra 97 is offline   Reply With Quote
Old 01-27-2013, 08:23 AM   #2
Cobrarunnin9s's Avatar
Have you tried checking or replacing the drivers side o2 sensors and also do you have the M.I.L. Eliminators installed?
Cobrarunnin9s is offline   Reply With Quote
Old 01-27-2013, 08:30 AM   #3
I was told when i bought it that it did have mil eliminators on it.. I havent actually gotten under the car to check. Reason being i was told that 02 sensor would not throw that code???
Old 01-27-2013, 08:44 AM   #4
Make sure they are their and on the correct set of o2s. They should be on the rear set. I had the same issue and that was the only part I changed besides o2s.
Old 01-27-2013, 08:57 AM   #5
I wiill check.. I was just thinking, if they wernt on there then i would imagine i would have a code for bank 1 and 2 right? and could it be the front sensor as well that just may have went bad? were you having the same problem i mentioned about the car running terrible until it warms up? it will idle fine its just taking off when its cold is when it wants to die?
Old 01-27-2013, 11:20 AM   #6
I'm not sure if both codes would come up or not. When I got my car it ran fine just really rich. But I also have other mods to. The guy that had it before me installed the mil eliminators on the front o2s instead of the rear so they did nothing at all. I have 2 sets because I didn't know he had em on there.
08:47 AM
