Need help! - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 02-07-2013, 07:16 PM   #1
03whitey's Avatar
Need help!
Trying to put x pipe on the cobra and broke 2 bolts trying to get the nuts off holding x pipe to manifold, i have no idea how to get these broken bolts out they are siezed in the manifold
03whitey is offline   Reply With Quote
Old 02-07-2013, 07:18 PM   #2
Heat works...and yes there is no room to work in there, i've been there.
Old 02-07-2013, 07:20 PM   #3
03whitey's Avatar
Well i thought about breakin out the torches but even if i could get it heated up idk how to get the bolts out i tried beatin a socket on that aint workin either
Old 02-08-2013, 05:17 AM   #4
WheelStander's Avatar
Good time to order some shorties maybe. It's gonna be tough to do at this point because of clearance.
Probably have to remove mani or tow to a shop unfortunately.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 02-08-2013, 01:30 PM   #5
pamson's Avatar
with no room to work you may have to pull the engine, drill a hole in the broken bolts, use heat and easy out bits
pamson is offline   Reply With Quote
Old 02-09-2013, 01:22 AM   #6
03whitey's Avatar
Well this might sound like a back woods mechanic type way of fixin it but i ended up cutting the bolts off even with the manifold and welding a bolt to where the old bolts use to be
Old 02-09-2013, 08:41 AM   #7
Apply direct heat to bolts, Spray Kroil Oil on them, repeat. If bolt snaps off, rent a tap and die set and do it the right way. Kit comes with extractor, bits, taps, die.
10:20 PM
