Lowering 96. Besides springs what do i need to buy? - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 02-20-2013, 11:23 PM   #1
Spiney's Avatar
I want to lower my 96 Cobra but not make the ride too harsh. I've already decided from other posts to go with progressive springs. Besides the springs, what do I need. I'd like to start and finish it on the same day. Do I need to by rubber isolators? Snubbers? The car has 44k and has been garaged all it's life. When you buy a kit from Eibach, does it come with everything you need? Thanks, Dave
Spiney is offline   Reply With Quote
Old 02-20-2013, 11:26 PM   #2
Venomouz831's Avatar
Look into aftermarket shocks and maybe CC plates. But with you're low miles you're oem shocks should be good. How much of a drop are you wanting?
)02 Gt, Founder of WE2G
Old 02-20-2013, 11:33 PM   #3
Rosco's Avatar
I found some bbk springs on ebay for cheap. The ride comfort is surprisingly well and are progressive rate. Check eBay and Craigslist for a deal.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 02-22-2013, 04:47 AM   #4
Caster camber plates (4 bolt), Bumpsteer kit, Steeda X2 balljoints if it's time for new ones or you need an additional 1/2"-1" drop up front. On the cheaper side of things, I am completely satisfied with KYB shocks/struts.
Old 02-22-2013, 07:42 AM   #5
at a mimimum:
Springs
Caster/Camber (for alignment HIGHLY recommend MM's 4 bolt CC plates)
Optional (needed if OEM are worn out where noted)
sway bar end links (shorter now that you are lowered)
shocks/struts (if OEM is in need of replacing)
new spring isolators, stay OEM ford on these the polyurethane ones are taller and reduce drop and squeek.
03:32 PM
