New user/question - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 03-03-2013, 08:01 PM   #1
Lovely97cobra's Avatar
New user/question
I just sol my evo and bought my first cobra....and im loving it so far, but after two weeks of owning her ive got a cel code of po171......anybody run into this problem,and have any advice on a quick fix?
Lovely97cobra is offline   Reply With Quote
Old 03-03-2013, 08:22 PM   #2
maldog's Avatar
Region: Nevada
It's a o2 bank sensor. This is a generic code in nature and its just telling you that by the time air got to the o2 sensor it failed certain parameters. It doesn't necessarily say you should go replace your o2 sensor.
When I got the same code it was my CAI when I cleaned it I over oiled it causing my code to come on.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 03-20-2013, 03:20 PM   #3
I disconnected the battery and cleaned the maf for starters, went through tons of start cycles, and here almost two weeks later the light came on, ran the diagnostics to find the same cel code p0171.....if an o2 sensor was bad, would it really take that long for the ecu to register again?
Old 03-24-2013, 08:16 PM   #4
Anybody?
Old 03-25-2013, 01:31 AM   #5
Coreyw428's Avatar
Region: Arkansas
Does it have cats on it?
Coreyw428 is offline   Reply With Quote
Old 03-25-2013, 03:32 AM   #6
DaBluedude's Avatar
Yes. I've seen the code before. I believe that is a downstream O2 sensor. If the car has the stock H pipe, get the O2 sensors checked. One is probably bad. If you have an aftermarket offroad Midpipe then you need a mil eliminator or a tuner to shut them off.
2003 Mach 1
Old 03-25-2013, 10:52 AM   #7
Car has bbk straight pipes to magnaflow mufflers.......if I needed mil eliminators, why when I bought the car, it took a month for this code to first pop up, figured it would have been on or come on quicker than that.....this is all new as im coming from the evo world...
Old 03-25-2013, 02:20 PM   #8
DaBluedude's Avatar
It's how the sensors are. Mine use to take about a week before they would trip. Don't worry about it. Totally normal. MIL eliminator work, but a tuner is better obviously.
2003 Mach 1
Old 03-25-2013, 05:50 PM   #9
Ive read mixed reviews,and supposedly a 97 cobra cant be tuned via handheld due to something to do with the type of ecu?
Old 03-25-2013, 06:31 PM   #10
stevec666's Avatar
The handheld tuner will work fine with your 97 Cobra. It's the 94-95 Cobras with the 5.0 that have to be tuned via a chip.
stevec666 is offline   Reply With Quote
Old 03-25-2013, 07:17 PM   #11
Thats a relief....
Old 03-25-2013, 07:18 PM   #12
2300turboford's Avatar
U should have a crap load of money for mods!!
Old 03-25-2013, 08:09 PM   #13
Mods arent my first order of business, im doing my research and waiting for the right time to build up a nasty street machine.
Old 03-25-2013, 09:36 PM   #14
Well forged internals and ported heads turbo kit of ur choice and suspension and m/t drag. Radials would be a good street machine
Old 03-29-2013, 10:37 AM   #15
Red face
My gut feeling, which is usually puts me on the right path tells me to use the very specified MAF sensor cleaner, nothing else. Slowly introduce Seafoam into upper intake, and a can of the best fuel treatment out there-*"CHEVRON TECHRON" FUEL ADDITIVE - 12 Oz;
Lastly check all CAI rubber clamped connections. Check ALL vacuum lines for leaks.
Old 03-29-2013, 09:50 PM   #16
Ive had a can of seafoam rollin around my floorboard for a few days....just waiting for when im gonna change the oil
Old 03-29-2013, 09:58 PM   #17
Krazy Horse's Avatar
There's a cheaper fix to the light instead of buying mil eliminators, buy 2 packs of the larger non foulers they use on old cars. Drill bottoms out of 2 of them then screw the drilled one on each side into non drilled ones and reinstall o2 sensors. The small hole into the pipe simulates convert delay to the pcm. Works every time for less than 20.00 $ and around 45 minutes work
Krazy Horse is offline   Reply With Quote
08:52 PM
