How hard is H-Pipe install?? - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 03-13-2013, 05:33 PM   #1
98StangKid's Avatar
I'm thinking about buying an O/R H pipe, and I need to know, how hard is the install? It's going on my 01 Cobra and I have the stock headers and stock h pipe on right now.
'01 Cobra
Forged Internals, Limited Slip Differential, 3:73s, Bama Tune, Pro 5.0 Short Shifter, Mach 1 Air Intake, 31 Spline Moser Axles.
98StangKid is offline   Reply With Quote
Old 03-13-2013, 08:24 PM   #2
stevec666's Avatar
Only issue I ran into when I did mine was 1 bolt snapped where it connected to my header and it was time consuming to remove, otherwise should go smooth.
stevec666 is offline   Reply With Quote
Old 03-13-2013, 09:10 PM   #3
98StangKid's Avatar
Oh ok. Cool. What all do you have to remove to get to it?
'01 Cobra
Old 03-13-2013, 10:07 PM   #4
COBRA97CW's Avatar
I'd be sure and soak the bolts down with some sort of penetrating fluid to help prevent from breaking them
COBRA97CW is offline   Reply With Quote
Old 03-13-2013, 10:17 PM   #5
Boomdizzle's Avatar
Definitely soak the bolts down multiple times with PB blaster. You'll need some long ratchet extensions and a swivel adapter also to have the most clearance. It really isn't that hard of a job to do, just very tedious and you have to make sure you get it bolted up correctly to the manifolds or you'll have a leak and will have to start over. I've done that a few times haha.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 03-14-2013, 01:16 AM   #6
Venomouz831's Avatar
Super easy! I've swapped out my midpipe about 3 times now and takes me about 15 min. Extensions and a swivel socket will make it much easier.
)02 Gt, Founder of WE2G
Old 03-17-2013, 10:25 AM   #7
98StangKid's Avatar
Thanks a lot guys. Sorry I disappeared. Lol. My SLP mufflers will be in soon, then I'll try to find a h pipe, then I'm buying a JLT CAI.
'01 Cobra
Old 06-22-2013, 05:36 PM   #8
540i6e39's Avatar
Easy
540i6e39 is offline   Reply With Quote
08:58 AM
