I can hear and feel something under my short shifter HELP - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 04-13-2013, 01:33 PM   #1
94 GT 5.0's Avatar
Hello fellow svt lovers, i just traded my 94 GT for this 97 SVT. So far i LOVE the car there is a HUUGE power difference.
But when im driving i can feel and hear something spinning real fast under my short shifter. I was just wondering if it's common with these cars or is there something wrong? It also makes kind of like a supercharger whining but there is no supercharger in the car, it happens when im on 3-4 gear and its only when i lightly step on the gas. If i gas it a little harder the noise goes away. Also the owner told me i might have to shim something but he wasnt real clear on it. Any ideas?
Oh yea its a 32V Cobra if that helps any? With the stock tranny
94 GT 5.0 is offline   Reply With Quote
Old 04-16-2013, 07:36 PM   #2
98C0BRA's Avatar
Could be flywheel chatter, which would cause your problem. If that's the case, dropping the trans and resurfacing your flywheel would be the answer. Do yourself a favor, replace the throw out bearing while your there, and if money isn't an issue, may as well do clutch as well. Good luck!
98C0BRA is offline   Reply With Quote
Old 04-21-2013, 12:36 AM   #3
My car has that noise too. Normal, a long as there is the correct lubricant & synthetic in tranny & differential, no worries.
Old 06-22-2013, 05:29 PM   #4
540i6e39's Avatar
This sounds about right. Center force clutch?
540i6e39 is offline   Reply With Quote
Old 06-22-2013, 07:24 PM   #5
98C0BRA's Avatar
I replaced mine with a king cobra. But center force is just as good.
Old 06-22-2013, 07:26 PM   #6
540i6e39's Avatar
My centerforce had tons of chatter, especially when it was cold. I loved my king cobra.
Old 01-22-2014, 11:36 AM   #7
94 GT 5.0's Avatar
Update: I thought it was trans giving me that chatter,I found the problem when I took her to get the differential clutches rebuilt. Turns out the carrier was cracked and had a broken pin holding the axles. I hurt so bad that I did a whole rear end rebuild
Ford Racing:
31 spline 8.8 posi Trac lok
3:73 gears
31 spline Aluminum driveshaft
And moser 31 spline axles.
No more chatter but I do need a new trans. Just my luck
04:25 PM
