Reverse gear grinding HELP! - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 04-22-2013, 06:25 PM   #1
94 GT 5.0's Avatar
Whats up guys im having some trouble with what im guessing is my tranny, whenever i put the gears on reverse i can hear the gears grind and it hurts to hear that lol. I can hear and feel something spinning under the shifter too. And when i try and put the gear in slowly i have to slow down whatever is spinning by putting the gear in halfway to make it stop. i can feel it grinding a bit but its not as bad directly putting it in reverse.
No other gears grind but when im on 3rd and 4th gear at low rpm's i can hear something in the tranny. The closest sound i can relate to these gears is the sound that comes from the back tires when getting a smog check or dyno done. Any help is appreciated. Thank you.
94 GT 5.0 is offline   Reply With Quote
Old 04-22-2013, 07:43 PM   #2
FortyBrandon's Avatar
Trans is gone. Bought a 99 cobra and I never drove manual before and I knew something was wrong because it kept grinding in 3rd and I never got it in 2nd. Coated me 1500 installation and a used 02 gt trans included. If you have to put another one in make sure you spend extra for a new one
FortyBrandon is offline   Reply With Quote
Old 04-23-2013, 12:49 AM   #3
94 GT 5.0's Avatar
Dang i was hoping it was something fixable. The gears dont grind on any other gears and they go in smooth, but like i said on 3rd and 4th gear it makes the sound of the machine the back tires spin on during a smog check. It only grinds and makes a thump when i put it on reverse quickly but when i put it halfway in reverse i can feel something spinning and slowing down as i go in and out of gear tapping whatever is spinning slowly to help it slow down.
Old 04-23-2013, 02:37 PM   #4
98C0BRA's Avatar
Syncros are wiped out. Def need trans, or rebuild. Look at the bright side, nows a good opportunity to upgrade to a T65 six speed! Haha
98C0BRA is offline   Reply With Quote
Old 04-23-2013, 10:39 PM   #5
94 GT 5.0's Avatar
Lol is it really worth the extra money? What will have to be changed? Will it fit my blow proof housing? And can i keep my short shifter.
Old 04-23-2013, 11:49 PM   #6
Yes and be sure to get your clutch changed to. My tob is going out and I should've done it while trans was out but I was stupid
Old 04-24-2013, 01:04 AM   #7
It's common flaw in the trans. Mine use to do it all the time something to do with the synchronizers but can be fixed. Try putting it in 1st gear then reverse sometimes it helps.
Bakiebruno5 is offline   Reply With Quote
Old 04-24-2013, 06:43 AM   #8
94 GT 5.0's Avatar
Good idea thanks
---------- Post added at 05:43 AM ---------- Previous post was at 05:42 AM ----------
Did you fix yours? How much was it if you did fix it?
Old 04-24-2013, 07:27 AM   #9
94 GT 5.0's Avatar
Hey man it worked!! Feels good nor hearing that
Old 04-24-2013, 07:38 AM   #10
2300turboford's Avatar
Try letting off the clutch and push it in wait 10 seconds then put it in
Old 04-24-2013, 01:01 PM   #11
94 GT 5.0's Avatar
Yea i tried that already it still grinds.
Thanks anyway. What i did was put it in first and the reverse and it worked!
Old 04-24-2013, 02:21 PM   #12
Best trick will help out a lot. I recently pulled mine and had them rebuild it. Had new synchronizers brass pads and all that good stuff for bout 1300. If I had a t5 would of just bought a new one but I have the t45 so had it beefed up
Old 04-24-2013, 02:30 PM   #13
It will still grind from time to time but don't force it.
Old 04-24-2013, 02:46 PM   #14
94 GT 5.0's Avatar
1300 isnt that bad for a rebuild. I have the t45 as well so i think ima just do that. Ill take a little grinding over making the trans grind and slam into gear. Thanks alot man
Old 04-24-2013, 11:30 PM   #15
Glad I could help drove me crazy till I started messing around with it and that was most effective way. The 1300 was me pulling it out myself and shop doing rebuild if I had the money would of loved to upgrade to tko or t56 but upgrading the t45 can make a hell of a trans
Old 04-25-2013, 06:45 AM   #16
94 GT 5.0's Avatar
Oooh ok. Dang ima have to look up some youtube videos to do that.
Did your car mske a weird spinning sound before you rebuilt it?
03:58 AM
