Running lean HELP! - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 06-06-2013, 01:57 PM   #1
94 GT 5.0's Avatar
Whats up guys, im having trouble getting my 97 cobra to pass smog and it's all because of 2 trouble codes. One says sensor indicates lean then a screen telling me my fuel system is faulty and the second code says as im running lean as well, it also says LACK OF H02S21 SWITCHES. Also the AIR and CAT's bubble is flashing on my obd2. i think my airbag is unplugged but i have no clue what to do on my cat's. here hare the pictures, thanks for the help.
94 GT 5.0 is offline   Reply With Quote
Old 06-07-2013, 08:52 AM   #2
Black99Snake's Avatar
Possibly one of your upstream o2 sensors may be out. Those tell your computer to lean it or richen it up. Google the dtc and see what it says. Or an injector or injectors.
---------- Post added at 01:52 PM ---------- Previous post was at 01:52 PM ----------
The 1151 is an o2 sensor
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 06-08-2013, 02:47 PM   #3
94 GT 5.0's Avatar
That's what im thinking, but if the o2 sensors were out wouldnt the CEL turn on?
Old 06-08-2013, 03:15 PM   #4
The cel is check engine light. You should have a light on if you pulled the p1151 code.
Old 06-09-2013, 02:46 PM   #5
94 GT 5.0's Avatar
Yea that's why im saying shouldn't it be on? Because it doesn't turn on, but the light does work. It turns on when i turn the key to on position. Thanks for the help by the way.
Old 06-12-2013, 07:39 AM   #6
Gottcha. Thats a strange one
Old 06-15-2013, 08:03 PM   #7
94 GT 5.0's Avatar
Yea man, it's pissing me off. I need to get it smogged so i can finally get it under my name!. If you think of anything let me know.
Old 06-22-2013, 03:27 PM   #8
540i6e39's Avatar
Most likely its the rear O2. Also car wont pass smog with the airbag light or cel on. It could be running lean from a cracked injector. I cracked a injector once changing my upper intake manifold on my 95 mustang years ago. Also check for vacuum leaks.
540i6e39 is offline   Reply With Quote
Old 06-24-2013, 04:25 PM   #9
94 GT 5.0's Avatar
+5 that's the answer i was looking for! Thank you!
Old 06-24-2013, 05:22 PM   #10
540i6e39's Avatar
Hope I helped
Old 06-25-2013, 03:11 AM   #11
94 GT 5.0's Avatar
Hope I helped
Sure did man thanks. I think you pretty much answered all the questions i put up on here, i appreciate it man. +100
12:51 AM
