Closed loop faulty? - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 06-11-2013, 04:27 PM   #1
94 GT 5.0's Avatar
Closed loop faulty?
Im confused to what this is? Can somebody please explain
94 GT 5.0 is offline   Reply With Quote
Old 06-22-2013, 02:34 PM   #2
540i6e39's Avatar
When the engine is first started, and rpm is above 400 rpm, the system goes into 'Open Loop' operation. In 'Open Loop', the ECM will ignore the signal from the Oxygen (O2) sensor and calculate the air/fuel ratio based on inputs from the coolant and MAF sensors, but mostly from a pre-programmed table in the memcal.The system will stay in 'Open Loop' until the following conditions are met:1. The O2 sensor has varying voltage output, showing that it is hot enough to operate properly. (This depends on temperature)*2. The coolant sensor is above a specified temperature about 40oC/104oF.*3. A specific amount of time has elapsed after starting the engine.The specific values for the above conditions vary with different engines and are stored in the mem-cal. When these conditions are met, the system goes into 'Closed Loop' operation. In 'Closed Loop', the ECM will calculate the air/fuel ratio (injector on-time) based on the various sensors but mainly the O2 sensor. This allows the air/fuel ratio to stay very close to 14.7:1.
I copied and pasted this but its simple. When you cold start your car the secondary air pump turns on till the car is warmed up and is in open loop which means the ecu isn't controlling anything. When the car warms up it switches to closed loop and the ecu is in control of everything. Also when you go wot it switches back to open loop I believe.
540i6e39 is offline   Reply With Quote
Old 06-24-2013, 03:34 PM   #3
94 GT 5.0's Avatar
Awesome thanks man. What could go faulty on it though? Because my 97 is throwing a code saying i'm running lean then it shows closed loop fault. Could it still have to do with my O2's?
Old 06-24-2013, 04:19 PM   #4
540i6e39's Avatar
bad O2,
Or a bad catalytic converter
Old 06-25-2013, 02:06 AM   #5
94 GT 5.0's Avatar
bad O2,
I really hope it's not the cats
Old 06-25-2013, 05:58 AM   #6
540i6e39's Avatar
Go down to your local muffler shop and you could probably get magnaflow highflow cats for 150 each. Thats what I get them for in the bay area or check craigslist.
Old 06-28-2013, 07:54 PM   #7
94 GT 5.0's Avatar
But will they let me pass smog?
Old 01-22-2014, 11:21 AM   #8
94 GT 5.0's Avatar
I forgot to update I replaced all 4 o2's and got rid of the code, got rid of missfires as well. I went to get my cats checked out and found out only the shells are welded on, both actual cat's arent there. I guess that's good since I have straight pipes. But not good cause now I need to pay 300 to pass smog checks.
03:50 AM
