Question about reverse grinding - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 08-06-2013, 10:14 PM   #1
mustangmar2001's Avatar
This has been going on for quite some time. It’s really difficult to put the gear in reverse sometimes because it will either grind, or it will go in reverse and pop out after a few seconds. At times, I have to put it in 1st gear then in reverse just to go, lol. But, sometimes that doesn’t even help. I had a new Hurst shifter put in a few months ago, thinking that it could solve the problem, but it didn’t. I’m thinking it could be the transmission? This is on a 98 Cobra btw.
mustangmar2001 is offline   Reply With Quote
Old 08-06-2013, 10:17 PM   #2
Black on Boss's Avatar
Sounds like the reverse synchro is bad.
Old 08-06-2013, 10:21 PM   #3
Venomouz831's Avatar
Bad synchro. Usually putting it in 1st then 5th helps out
)02 Gt, Founder of WE2G
Old 08-06-2013, 10:40 PM   #4
Billymich's Avatar
Yeah, fifth then reverse (no double clutch) or third then reverse.
Old 08-07-2013, 06:59 AM   #5
bigmac3's Avatar
In the old days (yeah, I'm one of them guys) the Ford top-loaders did not have a syncro ring on reverse because you were not moving when engaging. If you were grinding going into reverse, your clutch was not totally disengaging and a small adjustment would cure that problem. Are reverse syncros a standard thing on the current boxes or are you all assuming since the forward gears have them? Just wondering, I'm not up on the modern stuff.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 08-09-2013, 09:49 AM   #6
98C0BRA's Avatar
2nd and reverse share the same synchro. I had the same exact problem on my Cobra years back. Had to rebuild the trans.
98C0BRA is offline   Reply With Quote
Old 08-09-2013, 04:59 PM   #7
Honestly I've had some issues with my T45 too but its not bad. Just 1st, 1st, reverse or just get the car moving ever so slightly and it'll go right into reverse. Having a properly adjusted clutch cable also does wonders.
The t45 reverse issue is well known btw and there is a tsb out on it.
03:25 AM
