Code P1506, :( - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 08-19-2013, 07:46 PM   #1
94 GT 5.0's Avatar
Code P1506, :(
Whats up guys i finally solved my running lean and rich problem by replacing all 4 o2 sensors, all codes got deleted for a while, but when i checked the codes again one more popped up. Code p1506. Does someone know what i can do about this? Any input is appreciated, thank you.
94 GT 5.0 is offline   Reply With Quote
Old 08-26-2013, 10:17 AM   #2
Tkcobrasvt's Avatar
What car is this on?
Tkcobrasvt is offline   Reply With Quote
Old 08-27-2013, 10:21 AM   #3
94 GT 5.0's Avatar
It's a 97 cobra, if this helps any whenever i drive it no matter what speed i am going and i do a complete stop, the car idles at 1500 RPM for about 3-5 seconds and then slowly drops down to around 900.
So far i have replaced 2 IMRC top gaskets, intake manifold gasket, all 4 o2 sensors and EGR valve and gasket.
Old 09-05-2013, 07:49 PM   #4
98C0BRA's Avatar
Check idle air control valve, MAF sensor, or check to make sure no vacuum leaks
98C0BRA is offline   Reply With Quote
Old 09-07-2013, 06:33 PM   #5
94 GT 5.0's Avatar
Thank you i just switched the iac, control valve and pcv i will take it out later today hopefully it works. Wish me luck
Old 09-08-2013, 12:01 PM   #6
94 GT 5.0's Avatar
All codes are gone, but the final problem came out from the dark. My bank 2 cats are bad. And now my car idles at 1100 when i do a full stop and if i give it some gas while on neutral my RPM's go all the way down to 800 and surge a bit until staying at 900 it feels like it's gonna stall. Any ideas?
Old 09-08-2013, 02:01 PM   #7
98C0BRA's Avatar
I know it's expensive at $100 a pop, but change the oxygen sensors. Mine did the same thing, and after dumping a ton of money into changing sensors, it turns out to be the oxygen sensor.
Old 09-09-2013, 08:42 AM   #8
94 GT 5.0's Avatar
Yea man i replaced all 4 already i bought some bosch sensors, but since my rear right catalytic converter is malfunctioning the o2 sensor behind it wont get any readings. I plugged in my scanner and i saw that one sensor staying at 0.0
You think that's my problem? I know the cat's are a pain
Old 09-09-2013, 08:53 AM   #9
98C0BRA's Avatar
It's hard to say. I have a BBK H pipe with high flow cats, and I haven't had any problems after changing my O2 sensors. (Knock wood) I know how frustrating it is when they are not running right
Old 09-09-2013, 09:52 AM   #10
94 GT 5.0's Avatar
Niice! I have the stock H pipe on mine. Do you know or were you able to pass smog with the high flow cats?
Old 09-09-2013, 10:03 AM   #11
Adogg's Avatar
Hey man I have a 94 gt stock h pipe sitting on my back porch if want to buy the cats off of it? I am not looking for much?
Don't hate....... appreciate
Old 09-09-2013, 10:09 AM   #12
Did you get it worked out?
Here's the obd code site information about it, always found it to be the most useful
99 Ford Escort T. Codes: P1506, P0171 and P0420 : OBD-Codes.com
01LaserCobra is offline   Reply With Quote
Old 09-09-2013, 11:32 AM   #13
94 GT 5.0's Avatar
If the stock cats for your 5.0 gt fit my 4.6 cobra then i am willing to go pick it up. Ima see if there's any difference with SOHC and DOHC cats but thank you man
---------- Post added at 10:32 AM ---------- Previous post was at 10:27 AM ----------
Thank you, p1506 is gone but the code for my cats went off and it will not get any readings from the o2 sensor behind the bad converter
Old 09-09-2013, 12:38 PM   #14
Adogg's Avatar
My bad man I read you post to I should have know you had the 4.6. Just your name through me off I guess. But idk if there is a difference it might be worth looking into.
Old 09-09-2013, 01:53 PM   #15
94 GT 5.0's Avatar
Its all good man, happens to all of us. I made this profile when i had my 94 GT.
But hey im looking for certain parts that are probably on yours. Are you in the bay area?
Old 09-12-2013, 12:59 PM   #16
Adogg's Avatar
My bad with the delay and no not even close I am wave over in mass. I just noticed that you are from cali.
Old 09-12-2013, 10:12 PM   #17
94 GT 5.0's Avatar
No worries. Woah! that would be a very long trip for some cats lol
06:41 AM
