97 T45 to 99 T56 swap - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 09-07-2013, 06:38 PM   #1
94 GT 5.0's Avatar
So i found a good deal on a T56 and i need a transmission swap asap. Does anyone know if the cobra T56 will fit on my stock 97 cobra bell-housing? If not what modifications might be needed?
94 GT 5.0 is offline   Reply With Quote
Old 09-08-2013, 02:09 PM   #2
Black99Snake's Avatar
The t56 bell housing will fit your motor. Youll also need the t56 driveshaft or have yours shortened. Some say that the t45 crossmember wont fit with the t56 but it will. Why you swapping
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 09-09-2013, 08:28 AM   #3
94 GT 5.0's Avatar
So the t56 wont fit the t45 bellhousing? My t45 grinds when i give it a little gas but not when i hammer it and i dont know if it's normal but my shifter shakes alot when im on the freeway. On top of that it grinds if i put it straight to reverse i have to pop it in 1st then reverse. What would you recommend i do? Thank you for the input by the way
Old 09-09-2013, 08:42 AM   #4
First id have a transmission shop check it out. Might be something cheap and easy to replace than buying a $2300 trans and a $500 clutch kit and a expensive driveshaft
Old 09-09-2013, 10:42 AM   #5
94 GT 5.0's Avatar
Shoot man you're right. Plus all the labor wont be cheap either. Thanks for chiming in, i appreciate it
10:46 AM
