Clutch Fork Rattle - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 11-05-2013, 12:47 AM   #1
xhgwx's Avatar
Clutch Fork Rattle
So I bought my termi with one known problem, the clutch fork rattles and it's annoying and shakes the pedal, is there a known fix to this other than replacing the fork?
And how do you tighten the clutch cable as mine has about 1/4" worth of slack in it.
Any help is appreciated.
Has a stage 2 spec clutch in it if that helps at all.
xhgwx is offline   Reply With Quote
Old 11-05-2013, 07:19 AM   #2
You need to invest in a firewall adjuster and quadrant. The factory parts do ok with oem clutch but most aftermarket clutches need more adjustment.
I'm running a spec 3+ with fiore microclick firewall adjuster and steeda 3 hook quadrant. Only issue I have is bucking at low rpm's but that's expected from such a heavy clutch.
Old 11-05-2013, 10:01 AM   #3
xhgwx's Avatar
From this forum alone you seem to be one of the most knowledgable and most active cobra owners. What would be a good mod list shooting for 460-470rwhp with supporting mods and cooling mods and what order would you recommend
Old 11-05-2013, 11:16 AM   #4
2.76 pulley, idler kit of your choice with added idler below sc, mafia or sct2600, kenne bell bap and tune. Add a ported blower and you'll be just under 500/500 to the tires.
Some swear by cooling mods. My vert runs 11's on the setup I just posted. I didn't see benefit to head cooling mod. Added a larger ic tank and running stock heat exchanger.
Old 11-05-2013, 06:19 PM   #5
xhgwx's Avatar
Thanks man, that really some good info.
Old 11-05-2013, 07:02 PM   #6
Np. I've been messing with these cobras since 07 and have done most everything to one.
03:25 PM
