1996 cobra surging idle. - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 03-10-2014, 03:51 PM   #1
Hi guys I have a question I have a 96 cobra and it runs strong no problems when I'm driving but when I stop at a light it idles good for a few seconds then drops to about 500 rpms and surges it will not die but idles really low when I take off it does just fine. I can not figure out the problem and the car is giving me rich codes. I have checked for vacuum leaks and there are none . New idle air control valve new Maf new pcv valve and still the same thing. Could it be the o2 sensors my shop said they look stock. What do I do??
Thank you,
Carnell
carnellrules3 is offline   Reply With Quote
Old 03-20-2014, 02:14 AM   #2
Jlp06's Avatar
Region: Utah
Could be your O2 sensors, when's the last time you had your fuel filter replaced?
Jlp06 is offline   Reply With Quote
Old 03-20-2014, 06:34 AM   #3
Adogg's Avatar
I would recommend testing for bad parts and not just replacing cause this could be expensive. Do you have a cel?
Don't hate....... appreciate
Old 03-20-2014, 07:00 AM   #4
Yea I have a cel some times it stays off for a week or so and then comes on I just replaced o2s and that did not fix the problem.
Old 03-20-2014, 07:02 AM   #5
Adogg's Avatar
Yea I would stop just replacing parts, your wasting your money. Next time you get the code scan it and see what it says. If you haven't already.
Old 03-20-2014, 07:03 AM   #6
Also I have no cats and have the rear o2s tricked so they don't throw a cel has been this way for over 10 years and it's actually giving upstream 02 sensors running lean not rich but I have replaced them now and no fix .
Old 03-20-2014, 07:07 AM   #7
Adogg's Avatar
Yea I don't think the o2 sensors were broken they were actually reading correctly. This might not be it but did you check out your tps?
Old 03-20-2014, 07:15 AM   #8
No I have not I herd if you do the computer takes over and adjusts back to where it was. Well maybe the whole thing is bad can that be possible.
Old 03-20-2014, 07:17 AM   #9
Adogg's Avatar
Yea maybe man try unplugging your battery for 30 mins I think and it will reset every thing.
Old 03-20-2014, 07:18 AM   #10
Durnstang's Avatar
Plus one ⬆️⬆️⬆️ tps
Durnstang is offline   Reply With Quote
Old 03-20-2014, 07:25 AM   #11
Old 03-20-2014, 07:26 AM   #12
I have did that and had my mechanic clear out all of the short term and long term memory and that did not fix the problem maybe the whole part is bad is there a way to check .
Old 03-20-2014, 08:40 AM   #13
Adogg's Avatar
Way to test what? The tps?
Old 03-20-2014, 08:44 AM   #14
Adogg's Avatar
Try this first to make sure it's got the right voltage going to it and is functioning period which it probably is. If it doesn't try to adjust if still no luck then replace.
Old 03-20-2014, 08:59 AM   #15
Sure thing I'll give it a shot after work I hope it works ! Thanks man
Old 03-20-2014, 11:34 AM   #16
Adogg's Avatar
Not a problem good luck.
Old 03-20-2014, 03:03 PM   #17
Do I need to reset CPU after putting a new one in ?
Old 03-20-2014, 07:05 PM   #18
Adogg's Avatar
^^ you shouldn't have to, but if you want you can.
Old 03-20-2014, 07:06 PM   #19
Tryed a new one and no luck
Wanted: 03-04 Cobra bumper/hood + 1more stealthrz Mustang Parts for Sale and Wanted 0 03-02-2014 12:47 PM
208k 1999 Cobra Purchased, Need Advice!! 1999Cobra General Mustang Discussion 27 02-28-2014 09:01 AM
Cobra Pricing Opinions... 2008Shelby SVT Mustang 25 09-04-2011 03:49 AM
01:45 PM
