96-98 4.6 4V Specific, Mod Results - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 04-21-2014, 05:10 PM   #1
Found interesting mod result reading material for the 4.6 4V. Hopefully it is of interest. Also, these are opinions of this particular engine shop:
4.6L MUSTANG TECH Q&A
What rear differential gear do you recommend?
2V GT: The GT reacts to gear changes much the same way a 5.0 does although the real problem is that they have less torque than a 302.
For stick cars we recommend 3.73 gears. Because of the lack of low end torque, we don't feel 3.55's are enough. The 3.73 gives an excellent increase in acceleration and top speed isn't decreased because you are able to wind out overdrive further. With a 3.73 your rpm in 5th gear at 60 mph will only be 2005, not at all what you might call "too high". As we said, your top speed will not decrease when putting lower (numerically higher) gears in a car with overdrive. You will simply wind out 5th gear further than you could with the higher gears (numerically lower).
For AODE cars, 3.73's are still a good choice but we recommend 4.10 gears. A 4.10 may sound extremely steep, but because the AODE's 1st gear is higher (numerically low) and 4th gear (overdrive) is steeper than the T-5, it's a very good choice for the driver interested in making their car perform better.
4V Cobra: The Cobra has an entirely different engine than most people are used to. It performs best at high rpms, upwards of 7000. It's power band is relatively high due to the deep breathing nature of the two intake valves. When gearing a Cobra, 3.73's just aren't enough. They don't allow the engine to reach its power band quickly enough. 4.10 gears are an excellent choice and 4.30's are even better. This may sound very steep if you're used to the average 5.0 which needs to be shifted by 5600 rpm. But since this engine will easily rev to 7000 it needs the extra gear and it likes it. 4.30's are our #1 choice, naturally aspirated or supercharged. At 80 mph in fifth with 4.10's the engine only turns about 2700 rpm, completely tolerable.
I want to upgrade the exhaust system on my Mustang, what do you think?
2V GT: Traditionally, a free flowing exhaust system has always been an excellent way of increasing overall power. The 4.6L is no different but responds differently than a traditional 302.
Ford Motorsport makes a very nice set of headers for the 96 - 98 Mustang GT. They use a high tech coating to keep them from rusting and ensure long life. Their primary tubes are 1 5/8" and they offer a noticeable gain.
The most important thing to remember when choosing a high flow H-Pipe and catalytic converters is that the 2V engine is very sensitive and easily looses torque if the exhaust is too large. We recommend a 2 1/4" h-pipe, any larger and low end torque suffers significantly. And low end torque is what this engines needs improved the most. The Motorsport headers and a good h-pipe are worth approximately 25 hp.
4V Cobra: We have done extensive dyno testing with the Cobra's exhaust and found significant gains by using both headers and a free flowing h-pipe with converters.
As with the 2V engine, the 4V is sensitive to the size of the exhaust and can suffer torque losses if it is too large. We've used, with great success, a 2 1/4" h-pipe / converter set up that by itself is worth 15-18 horsepower. We have also dyno’d a set of stainless steel headers that by themselves are worth 25 hp and when combined with the h-pipe are worth 50 hp.
What are a few simple bolt-ons I can do for additional power?
Unfortunately, there aren't as many simple bolt-ons for the 4.6L engine as there are for the 5.0. But there are a few that are economical and make a difference.
Probably the best bang-for-the-buck you can do is putting in a lower (numerically higher) differential gear. One of the tech questions in this section address which one to choose.
Under-drive pulleys are always a good choice and are very affordable. Under-drive pulleys free up horsepower that was being used to turn your alternator and water pump. They slow down the operation of these accessories and allow the crank to spin easier. They'll add about 15 hp to your GT or Cobra.
A K&N air filter is also a good bolt-on that doesn't cost much. K&N Air Filters are constructed out of a high quality cotton fiber that is sandwiched between a metal screen. They offer the lowest restriction of any air filter on the market which means more power and better mileage. K&N air filters are washable and reusable and feature a 1 Million Mile Warranty.
Free flowing exhaust can get kind of pricey when compared to these other bolt-ons and isn't really much of a bolt-on. But once you've made these other modifications it's the next logical choice for affordable power.
Tell me more about supercharging my 4.6L Mustang.
Supercharging your Mustang is one of the most effective and substantial ways to increase its power and performance. When done properly, a supercharger offers an astounding increase in power without hurting gas mileage or overall drivability.
The only superchargers we carry are Vortech Superchargers because they are the best engineered, best built and most powerful available. Manufactured to strict aircraft tolerances, Vortech Superchargers offer an OEM-like quality, fit and finish. The kits fit like they were designed and installed by Ford. And the kits come complete with everything you need for the installation including auxiliary fuel pump and all hardware.
Vortech's S-Trim supercharger is the industry's most efficient and powerful street supercharger. It can supply more air than any other street unit available. And the 32V Cobra needs a blower capable of supplying large volumes of air. It is perfectly suited to the 4.6L engine and makes a substantial increase in power. Read more about supercharging the 4.6L in our Water Box Archives.
With a set of slicks and a 3.73 gear, an otherwise stock GT is capable of 13.40's @ over 102 mph and a Cobra with slicks and 4.30 gear is capable of 12.10's at over 114 mph. Of course, with street tires you won't be able to turn these kind of numbers, but the power will still be there.
Fox Body Specific Magazine SleepingStang 1979-1995 Mustang GT 7 08-27-2011 07:53 AM
Specific Number in the Bullitt Series bullittlover General Mustang Discussion 1 03-11-2008 06:12 PM
Specific underdrive pulley Justin-Heath Pre-2005 V6 Mustang 5 01-23-2007 06:11 AM
Specific seat delete cterie Mustang Audio & Video 13 03-23-2006 06:12 PM
Specific Targerts named for terror attacks Brent The Bar 34 08-02-2004 09:10 PM
06:24 AM
