01 svt cobra 3rd gear - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 08-21-2014, 11:08 PM   #1
I recently bought an 01 svt cobra. When shifting all gears work fine except to shift into third gear without it trying to grind i have to let it drop below 2k rpms. Any ideas why? So far i was told it might be the sync row however you spell it
Ic3man93 is offline   Reply With Quote
Old 08-21-2014, 11:33 PM   #2
This is common with the 3650.
The lowest cost "fix" to try to help with the "third gear wall" is to drain the fluid from the transmission and refill it with Mobil 1 synthetic automatic transmission fluid.
Many of the TR3650 transmissions were over filled at the factory and during subsequent fluid changes and this can cause "windage" problems at high RPM's and makes the transmission very difficult to shift.
The correct amount is precisely 3.2 quarts of transmission fluid.
If this doesn't solve, or at least help, your problem, then yes, it's most likely the synchro's in the transmission.
Old 09-18-2014, 08:33 AM   #3
Early run 3650s were notorious for syncrho issues and overfilling caused windage issues. The good news is a rebuilt one is not exactly breaking the bank and they are not very hard to swap out if you can get access to a lift.
I'd try 3.2 quarts of Pennzoil Synchromesh and see what that does. If not... probly a shot syncrho or something else boogered up internally. I just put a rebuilt 3650 in my 98 and it practically falls into gear at 6k. I hear all sorts of 3650 horror stories but when they are updated with all the TSBs, they are great transmissions.
svt
2001 SVT Cobra :: 2001 Ford SVT Cobra 98StangKid Member Garages 0 06-22-2012 03:49 PM
1995 Cobra SVT speedometer calibration gear McNassty AmericanMuscle 0 02-21-2012 02:14 PM
Grinding into 3rd gear tedness 1996-2004 Mustang GT 9 01-19-2010 06:32 AM
2008 3rd gear grind when cold gotmach Pre-2005 V6 Mustang 16 02-06-2009 07:07 AM
transmission stuck in 3rd gear need help theglory 1979-1995 Mustang GT 18 02-15-2006 10:20 AM
10:28 AM
