Interesting thing in the Cobra tonight - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 12-12-2014, 05:26 AM   #1
MC770's Avatar
Well I was on my way home from work at about 330am this morning when I was getting off the off ramp of the highway the cars battery light popped on and the car died, I was going about 65-70mph and had the heat on the lowest fan speed and the radio above an average volume due to the exhaust lol. I restarted the car and it was fine for about five to ten seconds when the exact same thing happened again. This time I cut off the fan and the radio thinking this could be something either battery or alternator related. After the second time it did not happen again for the rest of the ride home, my question for you guys is does that seem about right or is there other things you may know of as to why this happened?
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 12-12-2014, 06:01 AM   #2
Rapinator126's Avatar
Alternator. The 03/04 cobras are prone to the factory alternator failing. Swap it out.
Old 12-12-2014, 06:04 AM   #3
MC770's Avatar
Exactly what I had thought and was hoping I hate electrical gremlins, thanks man I'll deff be checking up on that alt
Old 12-13-2014, 11:51 PM   #4
XSlashDashX's Avatar
Yeah, definitely alt problem.
Old 12-14-2014, 12:24 AM   #5
MC770's Avatar
Well I think it may be related to my idle surge, when stopped the idle drops from 1k down to like 6-700 rpms and then bounce back and forth between them, I think it may have just been dropping too low and stalling?
Old 12-15-2014, 05:26 PM   #6
MC770's Avatar
Okay so the problem still persisit, when sitting still in neutral the idle will drop from 1k to about 500rpm and then go back and forth. However if I'm coming to a stop from about 50mph and just put it in neutral and brake to a stop the car will drop rpms all the way down to 100-stalling the car. I've pulled the IAC off and looked and cleaned it a little and the problem is still there, any insight would be awesome! thanks
This video is me coming to a stop from 50mph in netural
Old 02-23-2015, 01:44 PM   #7
Junior Member
My guess would be the to check the IAC valve then clean/replace as needed.
Sent from my SM-G730V using Tapatalk
psyviperx is offline   Reply With Quote
Old 03-12-2015, 09:50 PM   #8
No matter what, I use a Dremel tool the clean up every single connector from both sides of battery, Alternator line side (feeder wire) wire to alternator from battery area all cleaned up.
Old 03-15-2015, 10:57 AM   #9
Also, my car never ran perfect until i ran a small gauge ground wire from battery to alternator body. I used a 4 0r 6 gauge monster wire positive and negative side fused on positive side.
Going to the dag strip tonight. Looking for launch RPM tips 96 Cobra Spiney SVT Mustang 3 06-22-2013 03:09 PM
Is there such thing as a 1965 Mustang Cobra? hastiin General Mustang Discussion 11 08-22-2009 02:31 AM
Interesting project for a 96 cobra SpectorV The Bar 14 06-11-2005 11:33 PM
Some sort of import thing in huntsville tonight? SpectorV Regional Mustang Discussion 2 05-07-2005 11:21 PM
Interesting, very interesting.....hmmm Rick0636 The Bar 6 05-04-2004 12:06 PM
01:47 AM
