Brake dive - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 05-10-2015, 02:22 AM   #1
WFO
Brake dive
I've got an 01 cobra. Since the day I bought it, when you brake it dives to the left. Replaced pads and rotors all the way around. It did make it a little better but still doing it. Everything is wearing the same all around and temps are matched after heat cycles. Bearings feel the same all around and ball joints all feel tight. I'm at a complete loss. Any ideas? Only thing I can think of is abs manifold not pushing proper amount through all points. Any way to actually test that?
WFO is offline   Reply With Quote
Old 05-10-2015, 06:48 PM   #2
stealthrz's Avatar
How are your tires? A simple thing thats overlooked a lot. Just my 2 cents
2003 Mustang GT
DOHC 4V Swap
stealthrz is offline   Reply With Quote
Old 05-10-2015, 08:16 PM   #3
WFO
Brand new tires only 100 miles on them. Just had alignment done too.
Old 05-10-2015, 08:22 PM   #4
Maybe a caliper going bad.
Adventure till you drop
Old 05-10-2015, 08:50 PM   #5
WFO
That or bad abs manifold is all I can think of. I'm looking for some fluid pressure gauges and some applied pressure gauges now. Awesome knowing that none of the shops around here can diagnose brake problems without replacing parts. Nobody has gauges of any kind.
Old 05-10-2015, 08:52 PM   #6
Come to southern KY we have some. Do you know if the brakes were bled properly.
Old 05-10-2015, 09:28 PM   #7
WFO
As far as I know. I'm about to drain and fill the system to start from scratch. Figured I'd wait till the gauges showed up so I can do it all at once.
Old 05-10-2015, 09:33 PM   #8
Dot 3 or dot 4?
Old 05-10-2015, 10:00 PM   #9
WFO
Not sure what's in it. By the time I'm done it'll be dot 4
Old 05-11-2015, 12:13 AM   #10
Have all of the bushings in the suspension been CAREFULLY inspected for wear?
Your car has an IRS that can get out of alignment during moderate/heavy braking, yet be within specs during an alignment. Same thing with the front suspension...
These cars are getting to the age where every rubber bushing, in the entire suspension, should be looked at very closely.
Old 05-11-2015, 01:08 AM   #11
WFO
I'm just trying to get the scary dive to stop till winter. I'm doing a complete front and rear swap this winter. Everything except what I can't check yet checks out ok. I own my own shop and just lacking the proper gauges to check anything else. About to solve that problem though. Didn't know if the Cobras were prone to any known problems I was overlooking.
Old 05-11-2015, 07:19 AM   #12
stealthrz's Avatar
All else I could think of is front suspension and a brake hose/caliper not releasing or clogged. Good luck thou D:
2003 Mustang GT
DOHC 4V Swap
Old 05-16-2015, 10:20 PM   #13
Swap as in you are doing all the bushings or you are swapping to a solid axle out back?
Not sure what you mean by front swap unless you mean a full aftermarket K setup/coilovers.
If you are near NJ and are swapping to SRA I'm game to do a straight swap with a real low mile solid rear.
nose dive on 6th gen. TruChris 2011-2014 V6 Mustang 5 02-11-2013 01:09 PM
Whiteline anti-dive kits mmike87 2011-2014 Mustang GT 0 11-28-2012 06:48 PM
anti-dive M3hunter 2011-2014 Mustang GT 2 12-22-2010 05:57 PM
Disney Says "Dive In" PureVenom The Bar 15 08-18-2008 01:13 PM
05:51 AM
