03-04 Cobra Build/ what's neccesary? - Mustang Evolution
Go Back   Mustang Evolution > Shelby | ROUSH | Boss | Saleen | SVT || Tech and Talk > SVT Mustang
Old 10-25-2015, 09:11 PM   #1
Evolution's Avatar
I'm going to be going with the hellion single turbo kit over this winter and am looking to make anything over 600+ rwhp
I know cobra motors can handle lots of power, is it really worth upgrading pistons and valve train? Is it needed to upgrade transmission or anything? What do you guys recommend doing or is necessary to build when doing a higher hp build.
Motor has 49xxxmiles
Evolution is offline   Reply With Quote
Old 10-26-2015, 06:47 AM   #2
You will need at a minimum dual GT pumps, 60# injectors, maf of some sort. If still on 10 spline clutch I would look to upgrade to 26 spline with a nice rxt or something similar.
The IRS will hold up for a while but diff brace and solid diff bushings would be a need.
Sent from my XT1045 using Tapatalk
Old 10-28-2015, 09:32 PM   #3
Evolution's Avatar
I know the motor isn't necessary to build but is it worth throwing in better pistons and doing some port jobs and what not? Was going to do custom turbo cams and headers along with it and roughly what you had mentioned.
Old 10-28-2015, 10:05 PM   #4
The heads don't need any porting, maybe get them a valve job and cleaned up if you are feeling froggy. I'd just run it with a safe tune at 600whp. You'll need a ****load of driveline/suspension upgrades on that chassis to reliably support that sort of power on a 04-down car tho. I'd do all that stuff before adding more power TBTH. Or you'll just be spinning your wheels or breaking things.
Old 10-29-2015, 07:21 AM   #5
The pistons are the weak point. If you are shooting for 800+ and have a few grand just burning a hole in your pocket then go for it. Cams aren't worth the money in these cars either.
Old 04-03-2018, 06:36 PM   #6
Junior Member
I am also looking to build my 03 Cobra convertible looking for800 plus HP on pump gas possibly E85 also looking for a thousand plus on Race Fuel car is pretty much set up to handle power frame connectors welded straight axle conversion 5 link Steeda suspension strange axles good diff 373 gears carbon fiber driveshaft McLeod 1000 clutch Magnum tranny any ideas on engine block to build and or complete engines thinking 2.9 Whipple don't want to go turbo running small Kenny Bell right now actually since 03 with boosta pump want to save original engine and put aside only has 24000 original miles I'm the original owner bought it in Fall of 02 any help would be appreciated
Sent from my XT1585 using Tapatalk
vccishop is offline   Reply With Quote
« Pulley direction | - »
93 Cobra Replica Build! SaleenFiend 1979-1995 Mustang GT 16 03-23-2011 12:47 PM
Cobra R hood drainage pan (custom build) jimmy_beaner 1996-2004 Mustang GT 35 05-22-2009 08:19 AM
spring isolators neccesary? tedness Pre-2005 V6 Mustang 15 07-08-2005 10:20 PM
05:25 PM
