How To: Plasti Dip Your Car (In Depth, 6 pages worth of Microsoft Word) - Mustang Evolution
Old 12-24-2011, 02:25 AM   #1
Topless04GT's Avatar
How To Plasti Dip Your Entire Car
What you will Need
Plasti Dip (and lots of it)
1” Painters Tape (1 roll)
2” Painters Tape (2 Rolls)
Painters Paper (3 rolls)
Utility Knife Blades (2 Blades, no knife)
*Tools to remove Parts if you wish
Step 1) Wash the car
Take your time, do it right, remember this is going to be what the first layer of Plasti Dip adheres to. Get some good soap, some water, and a good amount of elbow time invested.
Step 2) Dismantle (See the bottom for How-To’s on removing these parts)
Remove any parts that would be easier to paint while off the car. The list of parts that I removed, are as follows:
Hood
Hood Scoop
Trunk
Front Bumper
Rear Bumper
P.S. – Remove the Lights for easier Painting. (i.e.; Fog lights, Head lights, and Tail lights.)
Step 3) Tape Off
It is that Lovely time where you have to mask off everything that you don’t want to get any Plasti Dip on. These were the areas that I taped off:
Windshield
Cowl
Rubber trim around the window baselines
Convertible Top
Engine
Wheels
Wheel Wells
Step 4) Start Painting
However you want to get the ball rolling just plan out your attack first. My method was I wanted to start with the Body itself because then I can get an idea of how it is going to look, and I can just add the parts that I paint as I get them finished.
Step 5) Flashlight test
This is a fun trick that takes some getting used to, but it in the end you will appreciate all the small time spent on making sure your countless hours are worth the struggle. Simply take an LED Flashlight, and get about an inch or two away from the paint, and look to see if you get any reflection. Because Plasti Dip is a flat plastic finish, you shouldn’t be able to see any clear coat from your original paint. My method to correct this would be print a picture of a mustang from the Top view, both side views, front, and rear. Make sure it is a pretty decent size, and draw a circle on the picture where you need to do some touch-up.
Step 6) Re-Assemble
Put the hood, trunk, and two bumpers back on the car at this point. For Stripes See Step 7, if you are not striping your car, skip straight to step 8.
Step 7) Tape Off (If adding stripes) ((Figured some people might so I should add this part))
Take your time and find the center of your car. The most true statement about something like this is “measure twice, cut once” well… you get the idea. You do not want to be excited to remove the tape to find that your center was off, nothing more depressing. So for this I will explain as If it were 12” stripes.
Step 7.1) Finding Center
Make sure when you find your center you determine how thick of a gap you want between your stripes, I chose 2” for this example, makes the math a lot easier. Once you have found true center, tape off the line from bumper, to bumper so you have your starting point. (Remember; take your time on this step, and it only makes things easier in the long run.)
Step 7.2) Measure Your Stripes
Tear off a few small pieces of painters tape, and as you are taking your 12” from center, apply the tape on the INSIDE of your outer edges of the stripe. (I will explain why on the next step) Do this about every foot or so, again from bumper to bumper. Repeat for both sides.
Step 7.3) Taping Off
Now the reason why you wanted the small pieces to be on the INSIDE of the outer edges of the stripes are so you can now simply take the roll of painters tape, and just drag and apply as you go along, making sure to line up with your tape marks. (When people put the tape pieces on the outside of that 12”s you have to take each piece off before going any further. This only makes is easier.) Again go from bumper to bumper and use for both sides.
Step 7.4) Masking Off
Now that the tape is down, Mask off the entire car. I know this may sound excessive but the last thing you want is for your two colors to have any, and I mean any type of overspray. I cannot begin to tell you how many people skip this step and they paint within the areas they have masked off, but then later they can see the overspray. Just do yourselves the favor and mask off the entire car at this point. Remember again, patience is everything when you do something to this magnitude of size.
Step 7.5) Paint Your Stripes
Start from the top and work your way down, so in a Coupe, you will start from the roof, from a convertible, start from the cowl, and work your way down to the front bumper, then from the trunk by the rear window, to the rear bumper.
Step 7.5-A) Technique
When painting something as easy as a 12” stripe start by going from left to right for your first coat, then just go diagonal top left to lower right, then diagonal from top right to lower left. (i.e.; --, \, /.) Also never stop spraying in an area of the stripe, ever! Always take your sprays beyond the tape line, and then stop.
Step 7.6) Cutting at the Line
Take your time with this one as it is the Make or Break point of your stripes. You need a sharp blade, and you are going to have to cut along the tape line from the length of the entire car “Four” times. I HIGHLY recommend going to a local Wal-mart and getting a Miners Light. (The kind that straps to your forehead) This way you can get close to your lines, and not have to fear the shadow that your cutting hand will cast.
Step 7.7) Removing the Mask/Taped Area
You can go at your own pace when removing the masked off areas, but when it gets to the tape that will have the edges of your stripes, Take. Your. Time. Slowly start from your highest point again, either the roof, the cowl, or the trunk, and find your staring point. Slowly start to peel back the tape and come off at a 45 degree angle. If at any point you see where the Plasti dip is catching, STOP, get your blade, and cut it free. Finish this part and your getting close to the home stretch.
Step 8) Removing Masked Areas
Now it is time to remove all of the other Masked off areas. Remember, CUT WHERE NEEDED along the lines that will show your clean edges with a blade. Anything else can simply just be removed.
Step 9) Finished
Step back and look at the marvel that you have created. Hopefully at this point you are worn out, yet in love with the results. Take your time and do a meticulous one over of the car trying to see if there is anything that needs to be touched up, but hopefully all was well in the whole TAKING YOUR TIME aspect of all of the steps above.
*****How To Remove Parts***** You Tube Videos Below
Part 1) Hood
Step 1) Remove the Hood Bolts
Locate the two bolts that connect the hood to the rest of the car at the hinge. You'll find one on each side of the hood. Remove the top bolt from each hinge using a wrench.
Step 2) With Assistance, Remove the Second Bolt
Have someone else hold each side of the hood up while you remove the second bolt. Take the bolt out of the hinge carefully and be sure to catch the hinge as it slides away from the hood. The other people holding the hood will have to also be careful that the hood doesn't scrape the rest of the car or come into contact with any parts of the engine
Step 3) Remove the Prop Rod and the Hood
Finally, you can remove the prop rod that attaches the hood to the remainder of the car. Gently lift the hood up over the top part of the car and set it down in a safe location. Keep the bolts and hinges along with the hood for reattachment.
Part 2) Hood Scoop
Step 1) Simply remove the bolts that have your scoop attached to your hood, lift and remove.
Part 3) Front Bumper
Step 1) Clean Off the Grille
Before you can remove the bumper of the car, it's important to detach any parts of the grille from the remainder of the car first. Open up the hood of the car, if you haven't yet removed it, and carefully detach any wires that are connecting the engine to the grille or the bumper. Make sure that the vehicle is powered off first.
Step 2) Remove the Bumper Bolts
Underneath the bumper of the car, you'll find four distinct bolts that attach the bumper to the remaining part of the car frame. Use a wrench to carefully remove these bolts and set them aside. It's helpful to have a second person to spot you and hold the bumper in place as you do this.
Step 3) Remove the Bumper
Gently pull the bumper away from the vehicle and lift it off of the frame of the car. Set the bumper and the bolts aside separately in a safe place for reattachment. Do not bend the bumper with too much pressure as you pull it off from the vehicle to separate it, as this could cause damage to the bumper.
Part 4) Trunk
Step 1) Open the trunk and locate the wires that run to the third brake light. Follow with your hands where they go until you reach a plug. Remove the plug and make sure the wiring is free.
Step 2) Next locate the bolts holding the trunk onto the hinges. Break them loose until you can unthread them the rest of the way with your fingers. Again get someone to help you because you will need to remove the trunk struts and then remove the bolts and take the trunk to a safe spot.
Part 5) Rear Bumper
Step 1) open the trunk take out the lining on the sides and near the taillights, you will have some bolts the come through. Take those nuts off, and then on the bottom side you will have plastic clips to remove.
Step 2) At the fender well you will also have some phillips head screws and the only way to get them out without taking the tire off is with a very short stubby phillips head screw driver.
*****You Tube How To’s*****
Hood, and Front Bumper -
If you have any questions at all PLEASE do not hesitate to ask.
Again do this at your own risk, I am not liable for any fault you may have when doing this to your own vehicle. Thanks!
I am underway and will not have pictures up of this process until the car is completely finished. I found it easier to plan my attack ahead of time and I currently have the car dismantled and a few parts all ready to go !
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Old 12-24-2011, 05:51 AM   #2
It's not me, it's you.
primer2tone's Avatar
Nice write up! Looking forward to seeing the pic's!
Old 12-24-2011, 01:14 PM   #3
Blogger
99ford's Avatar
+ 1
Old 12-24-2011, 08:39 PM   #4
Justasix98's Avatar
Wait.. You plasti dipped your whole car?! That's effin awesome! $150 in plasti dip sounds a lot better then my $1200 paint job haha.. But then again the color I've chosen, is amazing haha..
Very good instructions tho! Props too ya
Just A Sixxer!
Proud member of WickedStangs Okc Chapter!
Justasix98 is offline   Reply With Quote
Old 12-28-2011, 04:05 AM   #5
JetLife 01GT's Avatar
I've seen people mention plasti dip quite a few times now. What is it exactly and how does it work?
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 12-28-2011, 05:57 AM   #6
It's a synthetic rubber that comes in a spray can. You can pick some up at a hardware store for about $7 a can. You're right, there are quite a few threads about Plasti dip circulating around the forum.
I just wish someone would spray on themselves a Plasti dip wetsuit already! That would entertain me. That would be EPIC!
Old 12-28-2011, 07:10 AM   #7
Re: How To: Plasti Dip Your Car (In Depth, 6 pages worth of Microsoft Word)
Very interesting
Devildog1679 is offline   Reply With Quote
Old 12-28-2011, 01:24 PM   #8
02PONY's Avatar
Anyone ever paint over the plasti dip. If so is it still removable ?
02PONY is offline   Reply With Quote
Old 12-28-2011, 01:43 PM   #9
deadsp0t's Avatar
In one of these plasti dip threads, someone mentioned ppl were painting wheels after Plasti Dipping them and being able to take it right back off.
That's unimpressive
Old 12-28-2011, 02:48 PM   #10
Dead! Is that a Buro in a hole??? That is the most interesting thing I've seen all day! I just woke up, but I don't think today's events will top this! Lol
Old 12-28-2011, 02:57 PM   #11
deadsp0t's Avatar
Lol
That's unimpressive
Old 12-28-2011, 03:07 PM   #12
So you can pull of plasti-dip without damaging your rims? If you can pull it off it seems like it wouldnt last all that long. How long does it usually last and can you wash them with it on there? Sorry about all the questions guys but I'm interested in it lol
2001 GT
Old 12-28-2011, 04:06 PM   #13
Justasix98's Avatar
I've had my rims plasti-dipped about a month now, been through 2 heavy washes, rain, sleet, and cold, and it still looks awesome.. And yeah, it doesn't damage the rims at all.
Just A Sixxer!
Old 12-28-2011, 05:29 PM   #14
betojaimes's Avatar
+1
You'd think it would come off doing everyday things since it's easy to remove when you want too, but in fact it's really durable. I've driven through pretty decent sized pools of water at speed and it's still looks just as good as it did when I first did it! I've read posts about people that have pressure washed and everything without any trouble. It really does only come off when you want it too
betojaimes is offline   Reply With Quote
Old 12-28-2011, 06:14 PM   #15
Justasix98's Avatar
Originally Posted by betojaimes
+1
Heavy wash? I've scrubbed them with the foam brush and pressure washed @ the car wash, still looks really good! Another + is if you ever do scrape them, all it takes is a little touch up with plasti dip!
Just A Sixxer!
Old 12-28-2011, 10:34 PM   #16
About how many cans does it usually take to paint all 4 rims?
2001 GT
Old 12-28-2011, 10:41 PM   #17
Justasix98's Avatar
I barely did my 4 rims with 3 cans, I'd suggest 4 cans. I probably did 3, almost 4 good coats on each rim.
Just A Sixxer!
Old 12-29-2011, 12:52 PM   #18
Thx
So are the colors like a matte or satin color? They're not glossy right?
2001 GT
Old 12-29-2011, 01:15 PM   #19
ColeJohnson's Avatar
+1
Well just a heads up.. Plasti dip was originally created with the intent to be able to spray rubber grips onto tools and apply rubber where traction or protection from elements is needed. So yes, it's durable.
It sprays on looking glossy wet black, but drys to a matte black finish very reminiscent of KMC Rockstar rims, if you've seen those. The color is pretty awesome. And it took me 2.5 cans with 4 heavy coats for all four rims.
2016 Comp Orange GT (current)
Old 12-29-2011, 04:11 PM   #20
I wanna Plasti dip something! :/
Old 12-29-2011, 04:16 PM   #21
Justasix98's Avatar
Thx
It's a matte black, I also did my windshield wipers. Next I'm doing the bottom cutout on my rear bumper, and all the air duct covers on the exterior (hood vents & side vents)
Just A Sixxer!
Old 12-29-2011, 04:43 PM   #22
Pdip is coo but I have seen horror stories of people removing paint when trying to remove the dip also people not being able to remove all the Pdip that was in cracks and creases. I have also seen cars that had Pdip on it for long periods of time and it started to get pitted bad. People forget its made for tools not to make a car look good for long periods of time.
Doing small parts is fine and all but covering a whole car with $4-$7 cans spray on plastic made for hand tools. I will pass on that one.
OGBATMAN is offline   Reply With Quote
Old 12-29-2011, 06:39 PM   #23
Sorry guys, this is keeping me from doing any updates...
to answer a lot of questions
This Stuff will handle a lot of abuse as long as you are smart with it.
It Comes Off really easy, I removed my stripes in a decent amount of time in the afternoon.
Yes you can paint over it, it was the primary reason people started using it on wheels, Spray the Plastidip, and just test a color wheel, put them on the car, then they would just peel the plastidip, and actually paint them the color they choose.
Touch ups are easy if you do them right
The reason there is a horror story about the paint coming off when they guy removed the plastidip on his car, the dumb a s s used an industrial strength pressure washer to try to speed things up, nope he just fuc ked up his car.
I ended up choosing to do flat black and white stripes, and then I will also do those 20's in flat black with a white lip
KEY NOTE just remember, dont half *** or any project you do will have flaws. Do your research and all will be well. Trial and error ladies and gets, we all know that process.
Old 12-29-2011, 08:00 PM   #24
Pressure washer? Naw havent read that one. These guys were peeling it off and it peeled the paint right off....lol
Old 12-29-2011, 09:20 PM   #25
tdurham19's Avatar
Do u have any pics of the whole car plasti dipped?
---------- Post added at 10:20 PM ---------- Previous post was at 10:20 PM ----------
And OUCHHH! That looks painful
tdurham19 is offline   Reply With Quote
Old 12-30-2011, 03:39 PM   #26
shsfresh87's Avatar
Region: West Virgina
Quick ?, what's plastic dip?
shsfresh87 is offline   Reply With Quote
Old 12-30-2011, 05:45 PM   #27
Spray on rubber/plastic to protect hand tools. But people are now using them to paint cars.
Old 12-30-2011, 06:09 PM   #28
shsfresh87's Avatar
O, ok
Old 12-30-2011, 06:50 PM   #29
Nice write up!
MyStang68 is offline   Reply With Quote
Old 01-07-2012, 05:45 PM   #30
ForsakenProto's Avatar
Just did my hood today, 2 cans and about an hour later and this was the (awesome ) final result. Plan to do the bumper valance and trunk tomorrow
ID:	37557   Click image for larger version
ID:	37559   Click image for larger version
ForsakenProto is offline   Reply With Quote
Old 01-07-2012, 06:01 PM   #31
Wow, awesome job. That looks really good.
Old 01-07-2012, 06:06 PM   #32
JetWolf's Avatar
Send a message via Skype™ to JetWolf
Hmmm if you clear coat the plastidip it still peels off right...? :/
2006 JetWolf Gilbert, AZ. Come race me, I dare you. ASU!
JetWolf is offline   Reply With Quote
Old 01-07-2012, 07:43 PM   #33
Blogger
99ford's Avatar
^ what she said... & when removed the paint will be faded correct?
Old 01-08-2012, 02:01 AM   #34
plasti dip makes a clear coat now
Old 01-08-2012, 02:31 AM   #35
deadsp0t's Avatar
How about some pics? Want to see how it's coming along!
That's unimpressive
Plasti dip gone wild! Timm04 General Mustang Discussion 9 02-01-2012 08:52 AM
Removing stripes, plasti dipping the whole car Topless04GT Mustang Paint, Appearance & Detailing 15 12-15-2011 05:10 PM
01:34 PM
