Grille Removal - Mustang Evolution
Old 02-25-2012, 12:41 PM   #1
2003SonicBlue's Avatar
Grille Removal
Anybody a champ in this area? I need some help... And I'm think about painting it flat black. Let me know if anything else turned out nicely
2003SonicBlue is offline   Reply With Quote
Old 02-25-2012, 06:48 PM   #2
Horseplay's Avatar
its pretty easy bro. just remove the radiator cover and the screws on top of the grille. the pain will be the screws under the grille. check out american muscle and check out the mach grill and check installation and they give u an awesome step by step! or check youtube theres a video there that shows you how!
Low2v
Old 02-25-2012, 06:50 PM   #3
Horseplay's Avatar
oh and wen i first removed it i painted it flat black as well, except for the pony. then i just got the mach grille
wen i painted it
after new grille
Low2v
Old 02-27-2012, 10:51 PM   #4
I'm having a lot of trouble with removing the screws on the bottom.... They seem impossible -_- any tips?
Old 02-28-2012, 03:14 AM   #5
Horseplay's Avatar
well its pain in the *** man believe me! people told me it would be and it was!! my best tip is use a small socket wrench like i did, and with one hand hold up your bumper, and the other stick the socket wrench in there and try to get it in place. and whence the socket wrench is in there, with the hand holding the bumper up u can get your hand in there as well and hold the socket wrench down allowing you to wrech out those stupid little screws. and vise versa when re installing when done. thats my best way to explain it hope you can get it!
Low2v
Old 02-28-2012, 10:00 AM   #6
Re: Grille Removal
you need to take the bumper off, its actually rather easy to do
4 push pins under the bottom, reach up in the bumper on the inside of it where the bumper meets the fender (horizontal line) you can feel two 15mm bolts, remove those. Take out the headlights (two metal pins pull up then push out the headlight and unplug it). Take the two push pins off the bumper between the headlights and get a friend to help pull outward and then forward on the bumper at the sides.
Then you can get access to the grill to remove it.
Old 02-28-2012, 10:20 AM   #7
Thank you... I'll be doing this today! I'll let you know the out come
Old 02-28-2012, 02:24 PM   #8
Got it all out with out taking the bumper out. I also removed the side black pieces behind the doors and a black piece from my good... All being painted gloss black except for the pony. The silver outline will be black like in the mustang picture up there^ I'll take pictures later!
Old 02-28-2012, 04:40 PM   #9
Pics
ID:	42034   Click image for larger version
ID:	42036   Click image for larger version
Old 02-28-2012, 04:41 PM   #10
Pony looks weird because its covered in painters tape
Old 02-28-2012, 05:29 PM   #11
Horseplay's Avatar
nice !!! came out good !! how did u remove those inserts from the side scoops
Low2v
Old 02-28-2012, 07:45 PM   #12
They just clicked right out. Id say a flat head screw driver is easiest to pry with.
Old 02-28-2012, 08:23 PM   #13
Finishing up!
ID:	42055   Click image for larger version
ID:	42057   Click image for larger version
Old 02-28-2012, 08:42 PM   #14
DONE
Old 02-29-2012, 03:44 AM   #15
Horseplay's Avatar
DONE
nice job dude it came out awesome
Low2v
Old 02-29-2012, 07:29 AM   #16
I'll upload some daytime pics after I get out of school. It's a I'll rainy out but it'll look nice
Old 02-29-2012, 08:06 AM   #17
Scott2's Avatar
Re: Grille Removal
Looking forward to seeing the daytime pictures!
Old 02-29-2012, 12:28 PM   #18
Rain
ID:	42135   Click image for larger version
Old 02-29-2012, 01:46 PM   #19
Horseplay's Avatar
Rain
sweet !!!
Low2v
Old 02-29-2012, 01:51 PM   #20
Overall I like it better... I'd recommend it to most people looking for a simple cheap mod. Even if you want to keep everything original the darker black looks 100x better then the faded black my grille use to be. Some tips I have, take your time, sand with 200 grade sand paper for best results. I used Krylon fusion for plastic gloss black paint. I did four even coats and it dried very quickly, overall my car was without a grille for about 5 hours
Old 02-29-2012, 02:01 PM   #21
Closer
Old 02-29-2012, 02:22 PM   #22
Horseplay's Avatar
Closer
it came out badass. way better than when i painted mine !!
Low2v
Old 02-29-2012, 06:03 PM   #23
Thanks!
Old 03-03-2012, 12:15 AM   #24
Siendly22's Avatar
Where did you bought your spray paint bro, and how many did you use? It came out nice huh!
Siendly22 is offline   Reply With Quote
Old 03-03-2012, 09:40 AM   #25
One can from home depot Krylon Fusion for plastic gloss black
Old 03-03-2012, 11:08 AM   #26
Siendly22's Avatar
Thanks.
2002 Grille Ideas 02_Mustang Pre-2005 V6 Mustang 21 03-02-2012 02:50 PM
Exhaust/Grille for 2010 GT Kimber727 2011-2014 Mustang GT 24 02-13-2012 07:19 AM
Spindle removal ???? CrimsonGT 1996-2004 Mustang GT 0 02-10-2012 01:48 PM
new mach grille Horseplay Mustang Paint, Appearance & Detailing 9 02-08-2012 08:25 AM
Engine Removal 504 Stang Rida 1996-2004 Mustang GT 1 02-06-2012 10:09 AM
03:11 PM
